Saito Gas Conversion
I need a little help here.. A friend of mine pointed me in the right direction towards the CH conversion. But they have 2 conversions that seem very similar
I have an old stock glow saito 150 that id like to convert over to gas here are the two options CH sells Saito Glow CDI Conversion http://www.ch-ignitions.com/index.ph...cdi_conversion what is a GLOW CDI? i though only gas engines used CDIs Saito Gasoline CDI Conversion http://www.ch-ignitions.com/index.ph...cdi_conversion |
Originally Posted by MetallicaJunkie
(Post 11683837)
I have an old stock glow saito 150 that id like to convert over to gas here are the two options CH sells Saito Glow CDI Conversion http://www.ch-ignitions.com/index.ph...cdi_conversion what is a GLOW CDI? i though only gas engines used CDIs Saito Gasoline CDI Conversion http://www.ch-ignitions.com/index.ph...cdi_conversion CDI is merely a spark ignition system. It doesn't matter to the CDI whether it is lighting off gasoline or glow fuel. The big difference is power output. An engine converted to CDI properly tuned for glow fuel will make about 5% MORE HP than the GI (glow ignition) version while a gas conversion will produce about 15% LESS HP then the same engine W/GI. Taken together, CDI/glow fuel will produce greater than 20% more HP than a gasoline conversion. |
I have a old style CH ignition (from the previous CH company) on my Saito 150. It will run either glow fuel or gasoline.
I run the gas/oil at 20:1. |
Originally Posted by w8ye
(Post 11683915)
I run the gas/oil at 20:1. Just a bit of trivia: The "old" company was CH Electronics, http://i76.photobucket.com/albums/j3...psc32c1f63.gif the "new" is CH Ignitions. http://i76.photobucket.com/albums/j3...ps7b54411b.jpg http://i76.photobucket.com/albums/j3...psd158307b.jpg |
ok thanks for the explanation Telemaster....so that means ill need to go down in rop size if i do convert it to gas (gas CDI)? it happily swung a 17x6 using glow fuel....now ill have to go down to a 16x6?
It runs fine with the original carb. Has a rich spot around 5,000 where I stay above or below it.
I'm in Mcallen, I have a couple of the ch ignition conversion in both gas and glow, They run great. just converted fron my h9 1/4 scale cub back to gow with igniton and it spun a dynaflight 18-8 (ancient prop) 6600 rpm! with out tuning. gonna fiddle with it some more when I get time.
cool...it's rare to run into a "local" on here.... im gonna do a CH conversion too... i just need to get the plane back in flying condition first then ill work on the engine
Eddie, is this you?
Sure is.... Rick?
yep............. missed you at Tejas yesterday. we had a good time...............flew the cub with the C&h ignition on glow, runs really well.
Originally Posted by nonfanatic
(Post 11696566)
| All times are GMT -8. The time now is 08:21 PM. |
