Refreshing worn prop driver
This is on an engine I inherited.. the driver burrs or ridges are worn more or less smooth and don't grip the prop well. I don't [want] to tighten the prop nut excessively. Is there some sort of lathe or milling tool out there to recut a grippy pattern in the front of the hub driver. Engine is actually diesel but more eyes visit the glow site...
WP, I have seen a piece of sticky sided sand paper used for that, put the sticky side toward the prop driver, the sandy side against the prop,it works well and no problem to make a new one.
Originally Posted by wpadams
(Post 12501514)
The lather is run at moderate speed and the knurling tool advanced into the face of the prop driver-and the pattern on the wheel is reproduced on the surface it contacts [if the tool is not mounted on centre, a spiral pattern results from the use of a straight knurl-the spiral direction depends on whether it is above centre or below centre... As a rough approach-if you don't want to go to the trouble of knurling-you could use a dividing head and a internal thread tool in the tool post like a shaper: wind the tool across the face of the prop driver cutting a shallow radial groove; rotate the chuck a few degrees, repeat the process until you have a fully scribed prop driver.....but the knurling is a better option. https://cimg9.ibsrv.net/gimg/www.rcu...47b6d309be.jpg https://cimg1.ibsrv.net/gimg/www.rcu...244be9458c.jpg https://cimg2.ibsrv.net/gimg/www.rcu...1aa0977fcc.jpg ChrisM 'ffkiwi' |
Thanks for machining advice, I have diagonal knurling tools but forgot there are parallel ones too. BTW I have some engines of East European origin that don't have radial grip patterns; instead parallel ridges are machined across the entire driver face, cut very cleanly. So the radial solution is not the only one...
(Post 12501558)
This is a useful reference: Ron's Model Engineering and Model IC Engines Index see under 'resources' on the left hand side menu-it opens up and one of the subtopics is 'how to' ..click on that and the 7th topic on the 'How To' page is 'knurl prop drivers' ChrisM 'ffkiwi' |
what engine is this ??
you may be able to buy a new Hub here in this link,, Model Engine Company Of America Jim |
Originally Posted by the Wasp
(Post 12501820)
you may be able to buy a new Hub here in this link,, Model Engine Company Of America Jim ChrisM 'ffkiwi' |
| All times are GMT -8. The time now is 01:26 AM. |
