Niro engine MFG
I looks like all the nitro engine manufacturers are non existent. Does anyone know who is still making engines in to .46 to .53 range?
BTW, i have an OS 46 FX that needs a piston and sleeve. I cannot believe no one on earth has this part.!!! |
Originally Posted by mikefuture
(Post 12765498)
BTW, i have an OS 46 FX that needs a piston and sleeve. I cannot believe no one on earth has this part.!!! As for your FX: try to find an ASP or Magnum .46 twostroke that is still in good running condition. You should be able to pick these engines up cheap, for sure cheaper than the price of an original OS pison/liner replacement set. The piston/liner set of those cheap chinese engines is not only a direct drop in replacement for those of the FX, it is even MUCH better, being true chrome (mine gained 1000 RPM, and my OEM set was still pristine, undamaged and not worn out...). Out of an abundance of caution: Be aware that those piston/liner sets need to be replaced as a set, it is NOT possible to only exchange the piston or only the liner. It has to be the set, and also mark the orientation of the piston (which side is toward the exhaust) because mounting the piston 180 degrees rotated will ruin the fit if you try to run it. |
you can buy a K&B 48 hear in this link for $240. I believe they call this engine "the Screamer". I rather have it than any OS 40/46FX engine. just my opinion. you can buy other engines in this link too. but this 48 K&B seems to be the best buy. with mufflers the K&B should weigh close the same as your OS. they have the HP 40 too. but it's more money. both brands are super good engines, but old stuff I would have over a FX.
you can call them to see if they will build you a Webra. but I don't know if they have enough parts. Model Engine Company Of America - America's largest producer of Model Engines for airplanes boats and cars (mecoa.com) Jim |
OO looky here looky here. even less money.
.K&B Scremin’ .48 Goldhead R/C ABC NIB #2 - RC Groups Jim |
.46 &.55 glow engines are still available
Chief Aircraft (https://www.chiefaircraft.com/radio-...s-glow-engines) carries OS 2 stroke engines in .35AX, .46AX, .55AX, .65AX, .75AX, .90AX and 1.20AX sizes. They also carry Saito 4-cycle glow engines in a variety of sizes. The Saito FA-62B would compare well to a typical .40-.46 two stroke glow engine, but would be a little heavier. However, it would drink less fuel. Still lots of good used engines available for near dirt at RC flea markets. Check your local model clubs. I bet somebody will probably still have some .46 size engines in a drawer they would be willing to sell cheap. Old does not necessarily mean its junk. Yesterday, I flew my Goldberg Cub powered with an Enya .53-4C that has been on it since 1995 and it still starts and runs like new. My Enya R120-4C has been on my Phaeton 90 biplane since 1988 and it too still runs like new 35 years later. If you can find a used, but not abused, Enya .40-45 .50CX in decent condition, it should last a really long time and become one of your favorite engines. I think Enya engines are still being made, but you will have to order them from Japan (https://www.enya-engine.com/ListAP2CYL_E.html). They show a 50CX twin needle valve model rated at 1.7 HP that should start your tractor.
(Post 12765498)
(Post 12765498)
(Post 12765498)
(Post 12765498)
BTW, i have an OS 46 FX that needs a piston and sleeve. I cannot believe no one on earth has this part.!!! The 46FX-H heli engine cylinder and piston will fit. Its a ringed setup vs the FX ABC/ABN. I've done the swap and it all fits and runs the exact same as the FX ABC parts. Same port timing. Same bore and stroke. All the same except the ringed setup in the heli version. |
Personally, I favour "anything ringed from OS" over "anything ringless from OS"
Originally Posted by 1967brutus
(Post 12773207)
For racing, a properly fitted (expensive) ABC has been proven to run harder. Mainly, you can run massive ports without risk of the ring expanding into a port ajd hanging up. |
Originally Posted by Rcpilot
(Post 12773226)
For sport engines, I would agree. For me, a ringed setup lasts longer.
(Post 12773226)
Originally Posted by 1QwkSport2.5r
(Post 12773369)
More importantly is lack of worry about ring flutter in the ringless jobs. Ringed engines are cheaper to rebuild and renew, but true ABC and AAC spank ringed setups in every other aspect. I’ll gladly trade a ringed engine for an ABC/AAC any day. Properly treated from new, a quality true ABC/AAC can easily outlast a ringed engine though.
I don't mind having a GOOD non-ringed set-up, but when it's worn out, it's worn out and nothing I can do about it. It's a matter of principle because I've never really had too much issues with that, it's just the peace of mind in the back of my head that says, nah, I'll have the ringed one... |
I'm the same way. I don't race or fly competitively. A ringed sport engine is my preference.
(Post 12773596)
True, but I am more interested in durability, reliability and "refurbability". I don't care too much about balls-out all crushing power.
I don't mind having a GOOD non-ringed set-up, but when it's worn out, it's worn out and nothing I can do about it. It's a matter of principle because I've never really had too much issues with that, it's just the peace of mind in the back of my head that says, nah, I'll have the ringed one... Joking aside - ringed engines have their place. In the displacement size I use, it makes little sense to have ringed engines (mostly <10cc with the exception of a few 4-strokes and an ST S90 that are used on airboats and a couple ancient Enya 2-strokes). |
(Post 12773369)
Jim |
(Post 12773676)
I have had many ringed engines, and they ran fine. But the just weren’t as good as the ringless engines.
Originally Posted by 2W0EPI
(Post 12773722)
This, to me makes sense because with ringless ABC engines, the entire piston contact area forms the seal. Also, with rc ringed hobby engines usually only one ring is used surely a double ring engine would make a better seal?
(Post 12773839)
Two rings will seal better, but at the expense of higher friction.
| All times are GMT -8. The time now is 03:39 PM. |
