RCU Forums
-   Glow Engines (https://www.rcuniverse.com/forum/glow-engines-114/)
-   -   2-cycle plug for a 4-cycle engine???? (https://www.rcuniverse.com/forum/glow-engines-114/1194006-2-cycle-plug-4-cycle-engine.html)
Snyperx 10-10-2003 06:41 PM
Does anyone know if a standard long glow plug will work in a Magnum 61 4-stroke?? I have plenty of 2-stoke plugs. My local LHS does not carry 4-stroke plugs (small town) and would have to order them. I was trying to get in the maiden flight this weekend being the weather is perfect. Thanks.
w8ye 10-10-2003 06:46 PM
RE: 2-cycle plug for a 4-cycle engine????
One of the Enya plugs will work. It's the hotter one. Cannot remember the exact #.
Jim
3d-aholic 10-10-2003 06:50 PM
I think they work just not as well. They make the 4 plugs with heavy gauge stainless steel I think so they hold the heat better. If you use something else, keep your engine hot and don't idle.
jaka 10-11-2003 02:15 PM
Hi!
You should get an OS F plug!
No other glowplug will perform as well as this plug!
If you want to crash due to bad engine behaviour..... go ahead and try another plug.
Ps!
Enya 4strokes uses Enya 3 glowplugs ....so mabe an Enya 3 might work.
Regrads!
Jan K
Sweden
Rodney 10-11-2003 04:18 PM
The OS F is very good, probably best; but, the Fox Miracle Plug works very well also and is much less expensive.
bla bla 10-11-2003 05:00 PM
Enya nr. 3 is the plug in question w8ye
TLH101 10-11-2003 05:36 PM
I have to second the Miracle Plug. I use them in all my motors, 2 or 4 stroke and have for years. I dont need to keep a lot of spares because I seldom need to replace one. I am sure the others are good plugs as well but the Fox plug is considerably cheaper.
