RCU Forums
-   Glow Engines (https://www.rcuniverse.com/forum/glow-engines-114/)
-   -   HELP! Old K&B40 Broken Ring / Startup (https://www.rcuniverse.com/forum/glow-engines-114/1474381-help-old-k-b40-broken-ring-startup.html)
newart 01-28-2004 01:26 AM
1 Attachment(s)
I’ve had a broken ring on my old K&B40(model 4011 / produced until about 10 years ago). I’ve sent it out for replacement and cleaning and now when I started to run it won’t work at all as I was expecting. It won’t idle at low speed and it seems that it reaches full rpm at half throttle. If I open the carb fully it slows down and eventually dies. I’ve tried setting the needle valve differently but I get the same result.
What am I doing wrong(I even took the entire carb assembly out - thinking that it leaks air somewhere – and tighten it back in)? Should I replace the O rings on the carb and where can I get them from? (see my old post HELP ! Old K&B .40 on 1/4/2004)
w8ye 01-28-2004 01:51 AM
RE: HELP! Old K&B40 Broken Ring / Startup
There's a air leak somewhere? What about the back plate? I got my O rings at the local hardware store the last time but I have gotten them from the bearing store.
Enjoy,
Jim
newart 01-28-2004 02:45 AM
I don't know. It doesn't seem like. How can I tell?
w8ye 01-28-2004 08:31 AM
Your particular engine is a little newer than 10 years ago unless someone changed the carb on it.
While looking at your parts pieces in the picture, there are both a front piece and a back plate to your engine. But most important is the presence of only one gasket. Where's the other gasket?
Enjoy,
Jim
newart 01-28-2004 04:23 PM
1 Attachment(s)
There're two gaskets front and back (see attached picture/you might not see the front one as is attached to the crankshaft). They're not cracked and seem to be all right when I attached them to the engine. Also, while holding carb lever the carb barrel is not moving (up & down) but I thought if the O-rings are old maybe the air still can pass through.
MrMotor 01-28-2004 08:02 PM
How much break in time have you given the new ring? Is the engine too tight again to turn up to higher RPM or idle properly? When you install a new ring the engine needs to be broken in again to seat the new ring. Even Dykes rings need some break in.
newart 01-30-2004 02:11 AM
Yes you're right. I've done it and it runs good now. Thanks for your help. I've also changed the plug (it was too worn out and a little cold it seem).
