RCU Forums
-   Glow Engines (https://www.rcuniverse.com/forum/glow-engines-114/)
-   -   46 size evolution (https://www.rcuniverse.com/forum/glow-engines-114/1533530-46-size-evolution.html)
southwest737 02-16-2004 12:25 PM
46 size evolution
Has any body had any trouble with a 46 evolution. I started mine up right and it runs fine but the airplane i have it has to be mounted inverted and i can not seem to get it tuned
any commets of advise would be apreciated.
proptop 02-16-2004 06:00 PM
RE: 46 size evolution
I have the Evo engine from an Alpha in my Cermark Bobcat, and it's inverted. Took me awhile to get it right, but now, it runs great. I had to remove the blue limiter collars, so I could lean out the idle mixture enough so it would stay running. Just exactly what kind of trouble(s) are you having?
southwest737 02-17-2004 12:34 PM
Well when you trie to adjust the fuel mixture it is like way to touchy . One click on the needle valve makes it go really lean and then you click it one back and it goes way to rich. I cant get it adjusted because one click is so critical.
