RCU Forums
-   Glow Engines (https://www.rcuniverse.com/forum/glow-engines-114/)
-   -   Engine (https://www.rcuniverse.com/forum/glow-engines-114/155304-engine.html)
arjunchopra 06-06-2002 03:34 AM
Engine
Engine I am presently using an OS FX 46 .
I am trying to upgrade to a 61 or 90 . Would liek your reccomendations on which engine do I purchase, keeping in mind the following :
1. Price .
2. Reliability .
Thanks .
AQ500 06-06-2002 04:10 AM
Engine
OS makes the 61 FX as well as the 91 FX. They are both reliable and a little more expensive than the competition. The 91 is slightly lighter than the 61. You will have to consider prop clearance. I have had experience with the 61 FX and it is a good running reliable engine.
That is a big step.....46 to a 91. Are you sure you want to go that high? What plane is it? The 91 will turn a 13 to 14 inch (33.3 to 35.8 cm) prop.
If you want a little more power without having to buy a new engine try a Nelson Ultrathrust muffler. Again, I said a LITTLE more power.
