MDS 148 ENGINE
I JUST PURCHASED A USED MDS 148 ENGINE AT THE PERRY GA SWAP MEET. IT DID NOT HAVE A MUFFLER. WHO MAKES A MUFFLER FOR THIS ENGINE. ALSO DOES ANYONE KNOW IF THIS IS A STRONG ENGINE OR EASY TO CRANK AND SUCH. THANKS FOR ANY INFO
RE: MDS 148 ENGINE
The Bisson Webra 120/ MDS 148 will fit. Run 5% nitro with 20% oil mostly or at least half castor, a H9 superPlug or Fox Miracle. Starts by backflipping are one flip affairs after priming. See if Horizon will send you the 10MM carb for the 2.18, it has MDS cast on the front. Although the stock C1 carbs on both of mine were fine.
| All times are GMT -8. The time now is 02:49 PM. |
