RCU Forums
-   Glow Engines (https://www.rcuniverse.com/forum/glow-engines-114/)
-   -   2 Stroke Engine Priming (https://www.rcuniverse.com/forum/glow-engines-114/1679524-2-stroke-engine-priming.html)
Funfly123 04-01-2004 04:07 AM
Can anyone suggest the best way to prime a fully cowled engine. The engine is an ASP 91 and it is side mounted, the fuel tank is mounted within the fuselage on the same center line as the carb there is no access to place your finger over the carb and turn the prop at the same time.
Many thanks in advance
HavinFun 04-01-2004 04:34 AM
RE: 2 Stroke Engine Priming
Put your finger over the exhaust outlet & rotate prop, works the same,:D
ooooo 04-01-2004 07:04 AM
What HavinFun said......with the carb fully open. If you use an electric starter....it is said you don't have to prime the engine. The high rate of turn over by the starter sucks the fuel into the carb anyways.
Hope this helps.
impactiq 04-01-2004 02:56 PM
Like said before the starter will do the job. Just do it with the glow ign. off.
SwampFlier-RCU 04-01-2004 03:50 PM
Ditto on the exhaust, priming it will result in less turns with the electric starter :)
Funfly123 04-02-2004 02:58 AM
Many Thanks for the advice
Andy H
