Crashed Engine (Will it rise from the dead?)
I crashed my OS .46FX hard this spring (Into really soft mud though). I cleaned it all out. I checked the crankshaft and it isnt broken, but i know all the water i ran through it makes it in need for some serious lubing. What is the best way to lube it up? Should i take off the backplate and spray a little WD40 in there? Or should i try to run some nitro through it (Seeing that it's about 50% oil anyways). I dont want to damage my engine by starting it up without enough lubrication. Thanks
RE: Crashed Engine (Will it rise from the dead?)
Dude:
Pop the backplate and hope you haven't waited too long. Dry it as well as you can, oil it up with some Dexron automatic trans fluid, (avoid WD-40 in these engines) and see if it turns smoothly. Waited too long? If it's been sitting since spring with water in it you may have ruined the bearings. But if it turns smoothly, put the backplate on, reinstall the plug, and go fly. A point of warning: The 46 FX has a nickel plated cylinder liner, be meticulous about getting all the trash out. One small bit of grit can start the dreaded "Peeling Liner" condition. For this reason don't take any chances with the bearings. If not smooth when turning, replace them before running the engine. Bill. |
| All times are GMT -8. The time now is 06:26 AM. |
