Assembly Lube
Hi;I am rebuilding a K&B .61 and a ST. 51 and before I put them back together what kind of assembly lube should I put on bearing surfaces and the ring/ sleeve so that thay will not have a dry start? Thanks........Veco
RE: Assembly Lube
Veco:
A 50/50 mix of ATF and castor oil works fine, or you can also use straight Automatic Transmission Fluid if the engine is going to sit for a while. Bill. |
| All times are GMT -8. The time now is 11:09 AM. |
