RCU Forums
-   Glow Engines (https://www.rcuniverse.com/forum/glow-engines-114/)
-   -   Engine craps-out in the air... (https://www.rcuniverse.com/forum/glow-engines-114/20429-engine-craps-out-air.html)
miamiquasar 09-01-2003 03:01 PM
Hi folks,
Lucky thing(& no wonder) I fly electric too,or I'd get very little flying done indeed...as I've had rotten luck with several of my engines.I have recently began ATTEMPTING flight with my old OS.40fp again & remembered just why I put it away years ago!The engine will run perfectly on the ground,Starts easily,idles reliably & will run the tank dry without a problem...but as soon as you attempt flight & climb-out for a few seconds it will die.Every time.It frustrated me into "retiring"the engine years ago & seems to headed towards "hammer retirement"now!!!
It's probably something simple too...
Any advice would be appreciated.
Thanks.
M.Q.
daveopam 09-01-2003 09:32 PM
Will it run on the ground with the nose pointed straight up?
guitarob16 09-02-2003 12:12 AM
Daveo is probably right. The needle valve is probably not adjusted correctly. Do what he said, hold the model up with at least a 45 degree angle for a few seconds and see what happens (full throttle). If the engine quits, its definatley too lean. richen it up by turning the needle valve counter clockwise.
miamiquasar 09-04-2003 06:54 PM
Hey there...
Yes, the engine runs when in a vertical attitude on the ground.As do all my other engines.I use a digital tach to set the needle & do not believe it to be a question of leaning.I am about to check the tank & maybe replace the plumbing.Maybe tear the carb off & clean it out too.
Keeping my fingers crossed(not while flying).
Regards.
M.Q.
miamiquasar 09-06-2003 06:04 PM
Oh Brother...!!
I mean come on...Shame on me!!This is a modified trainer that I hung up years(9)ago due to a "balky"engine which began to quit in the air.I am now flying high performance stuff & have maybe 17 or so models ie/ sport,warbird,biplane,sailplane,slope,electric,sca
le,float,scratchbuilt etc.A couple of times over the years I have even taken the model down & gave it another try to no avail.It still quit in the air with fresh fuel & plug & cleaning & yadayada.For nine years I have had a perfectly good engine hanging above my head in my shop in a model with a kinked tank line!!!!!HAHAHAHAHAHAHA!I couldn't spell a loud enough Homer Simpson "DOH!!!!" to express the one I felt!
Nor is the smilie I have selected near large enough to express the one I wore all yesterday afternoon,running a half gallon through that old trainer & I mean IN THE AIR!!!
Now the trainer retires for real & the engine finds new life in any number of projects...
Nine years modelling experience later & I overlooked one of the fundamentals...Oh well,It turned out to be a happy ending afterall.Thanks. Regards.M.Q.
