RCU Forums
-   Glow Engines (https://www.rcuniverse.com/forum/glow-engines-114/)
-   -   Engine stands (https://www.rcuniverse.com/forum/glow-engines-114/2077515-engine-stands.html)
highace 08-12-2004 03:45 AM
Engine stands
Hello,
Does anyone have any tips/ideas for an engine stand. I have a .25fp that i would like to run in. Dont know if it has been run in properly so i will do it again.
Anyone know of a procedure for a 0S 25fp?
Ace
Hobbsy 08-12-2004 07:25 AM
RE: Engine stands
I have several engine test stands and the best by far is the PSP.
DarZeelon 08-12-2004 08:47 AM
RE: Engine stands
Alexander,
Your engine is probably a tapered-bore ABN design.
If it is, [link=http://www.rcuniverse.com/forum/m_1850473/anchors_1850473/mpage_1/key_tapered%252Dbore%252Cbreak%252Din/anchor/tm.htm#1850473]this thread[/link] illustrates the correct break-in procedure.
I have heard of some older versions of this engine, that are lapped meehanite piston designs, so please verify that your engine isn't one.
The correct procedure for a tapered-bore engine, will turn a lapped piston engine to junk.
This is also correct vice-versa, to a lesser degree.
So before you proceed, verify the type of engine that you have.
