RCU Forums
-   Glow Engines (https://www.rcuniverse.com/forum/glow-engines-114/)
-   -   Moki .61 LS (https://www.rcuniverse.com/forum/glow-engines-114/20991-moki-61-ls.html)
Hobbsy 12-02-2001 11:30 PM
Moki .61 LS
I fired up a new Moki .61 Long Stroke yesterday and had a problem. When reducing the throttle to about one third the fuel would suddenly flow back into the tank and the engine would quit. I discovered that the clip that keeps the needle valve from turning on its own had too big a hole in it. Air was leaking through the hole and into the banjo fitting that the fuel line attaches to. I found another clip with the perfect sized hole in it and put a gasket on each side of the banjo fitting. Today it will idle perfectly and turns a Graupner 12.5x5 wide blade at 11,700 RPM. Im mounted it on my BTE Venture 60.
Captain John 04-14-2014 10:58 AM
The Moki engines are tops in my book.
