Enya engine specs???
I have been looking all over the web for Enya engine specs,and can't find any? Can anyone help me out? I'm looking for the specs on the SS50 airplane engine. I can find specs. on every other engine out there. Except Enya. What's the deal? :confused:
RBECK |
ss50 specs
Sorry about that. We are reconstructing our website to add that motor and update. Unfotunately it take a little bit of time.
The sss50 is a two piece case ringed engine that has 1.3 bhp and a range of 2500 to 17,000. If you would like to have more dimensions etc call us at 732 225-6144 and ask for carol or tim. they can get you the info while I am away. The mounting dimensions are the same for 40 to 46 size motors both in motor mount and exhaust port. The carb is a two needle style with a safety needle angled back at a 45 degree angle. Works well. Thanks Jeff G |
Enya specs.
Thanks for the reply. Do you have any idea when the web site will be ready?
RBECK |
website
Not off hand. It is a slow process for us, but it is looking nice. I am sure it will kick into full gear here real soon. It is being revamped. :)
Jeff G |
Info on the Enya 1.55
I am looking for info on the enya 1.55 4-stroke.
I have a 120 R ... currently at your shop for repair ... I want to know if the bolt pattern is the same as I want to mount it in where the 1.20 sat in my Citabria Pro. And how much bigger prop I can swing along with how much power gain I will get over my 120 R? |
can you tell me the prop nut thread size for an Enya 40 marine engine? I'm trying to complete the prop drive train in a boat.
7 x 1 mm
Thanks Jeff G |
| All times are GMT -8. The time now is 07:58 PM. |
