RCU Forums
-   Glow Engines (https://www.rcuniverse.com/forum/glow-engines-114/)
-   -   Horizontal prop (https://www.rcuniverse.com/forum/glow-engines-114/22602-horizontal-prop.html)
lbrannan 12-09-2001 06:57 PM
Horizontal prop
I'm building my third Diamond Dust (guess what happened to the other two!). Since there is no landing gear, how do I set the prop to insure that when I land after flying out the tank of fuel that the prop will be horizontal. Should the prop be at full compression (top dead center)?
thanks,
Larry Brannan
ChuckAuger 12-09-2001 08:11 PM
Try this...
Run the engine to get it up to temp, then set the prop where it is horizontal when the compression stroke is just starting, ie the exhaust port is just closed.
lbrannan 12-10-2001 12:13 AM
Horizontal prop
Thanks Chuck!!:p
