YS120NC engine mount?
I'm building a H-9 Funtana 90 and putting a YS120NC up front. I understand I should put this engine in a soft mount. I got the engine used form a club member, soI've never mounted it. Anyone used the Dubro soft mount with this engine? Is it a good application? I read in the pattern forum that the Hyde soft-mount is the best but I just don't have $109 for a engine mount. Thats half the price of the plane!! Any other reasonable suggestions?
Thanks for the help. |
RE: YS120NC engine mount?
these mounts reduce vibration.........does it vibrate that much that you have to spend $19.00?? Man a good prop and spinner should do you; unless the crank is bent! I have seen these mounts CREATE vibration!! Sullivan makes them too and are cheaper!
The Slip! |
