RCU Forums
-   Glow Engines (https://www.rcuniverse.com/forum/glow-engines-114/)
-   -   help with a TT .61 (https://www.rcuniverse.com/forum/glow-engines-114/2337276-help-tt-61-a.html)
caseyh46 11-11-2004 10:13 PM
help with a TT .61
Hi fellas, I have a quick question and thought I'd post it and hopefully ya'll can enlighten me. I'm building a TF Spitfire and well silly me I ended up ordering and Thunder Tiger .61 engine instead of the Super tiger .61 engine from Tower Hobbies. My question is where can I find a header for it that will go back to the in-cowl muffler that the plans/instructions calls for, tower dosen't seem to have one? I got the header for the Super Tiger engine and ofcourse it won't fit the TT. Or, should I just send the TT .61 back and re-order the Super Tiger .61. Any help or advice would be awesome.
Casey
MrMotor 11-11-2004 11:46 PM
RE: help with a TT .61
Casey
The header that fits the OS 61 will fit the Thunder Tiger 61 also.
bob27s 11-12-2004 10:53 AM
Casey,
TT61 muffler attachment is same OS61/91FX bolt pattern....as noted above.
Engine runs well. If you were to swap it out for anything, see if the TT91 is available yet. Same size engine. Will give you the ability to turn a 14" prop on the spitfire.
