RCU Forums
-   Glow Engines (https://www.rcuniverse.com/forum/glow-engines-114/)
-   -   3 blade prop (https://www.rcuniverse.com/forum/glow-engines-114/2387057-3-blade-prop.html)
serge760 11-29-2004 07:25 PM
3 blade prop
what is the best size 3 blade prop for a 61fx 2 stoke????????????
voyager_663rd 11-29-2004 07:54 PM
RE: 3 blade prop
1 Attachment(s)
Here ya go:. Just substitute for what you're using now. For example, on a three bladed propeller you would drop the diameter and keep the pitch. On a four bladed, you would drop the diameter and the pitch. For instance if you had a two bladed 24-10 propeller and you wanted a three bladed you would use a 22-10 and so on.
serge760 11-29-2004 08:39 PM
RE: 3 blade prop
thanks for your help
serge
voyager_663rd 11-29-2004 08:50 PM
RE: 3 blade prop
YW
