RCU Forums
-   Glow Engines (https://www.rcuniverse.com/forum/glow-engines-114/)
-   -   gms 47 problem (https://www.rcuniverse.com/forum/glow-engines-114/2587413-gms-47-problem.html)
matt flyer 01-26-2005 06:03 PM
gms 47 problem
My engine is mounted on a pro twister and in the needle valve dosent work at 1/2 or at 5 turns out it is the same the engine is side mounted cause it is a profile. it is always lean like one turn out. can someone please help me.
w8ye 01-26-2005 06:06 PM
RE: gms 47 problem
Try opening up your idle mixture screw a little?
Enjoy,
Jim
Flyboy Dave 01-26-2005 08:04 PM
RE: gms 47 problem
There is a big thread on the GMS .47....[link=http://www.rcuniverse.com/forum/GMS_Engine_Tuning_Problem/m_2290854/tm.htm]click here to read it.[/link]
Dave. ;)
matt flyer 01-26-2005 09:12 PM
RE: gms 47 problem
Thanks but i forgot to mention that the needle valve was very sensitive when i bench ran it (upright) but now sidemounted on the profile it dosent work.
Flyboy Dave 01-26-2005 11:24 PM
RE: gms 47 problem
Mine HS needle is very broad since I did those mods, it is side mounted. ;)
I had a partially restricted fuel inlet.
FBD. :D
