Spinner Sizing
OK......this may be basic to a lot of you, but spinner size selection has always been a mystery to me.
How do you determine what size spinner to use with what size prop and what size engine. Same goes with prop hubs. There.....it's as simple as that........please explain to me so I know what I'm doing in the future. Thanks, Andy |
RE: Spinner Sizing
the basic formula is 20 to 25% of the diameter of the prop.....but it is also up to you and what will fit your airplane the best....
depends if there is a cowl etc. etc. but I have found the 20/25% rule gets me in the ballpark to start looking |
RE: Spinner Sizing
I've always picked the size that would "Flow" into the rest of the plane and not worried about any formula. This has always worked for me.
Bill. |
RE: Spinner Sizing
Hello!
Selecting spinner! Pick whatever fits the fuselage shape...it is that easy. Regards! Jan K Sweden |
RE: Spinner Sizing
Well, it depends on what type of plane. If it's profile, then any spinner will be too wide, and it's best to use a hub to save weight.
For a radial cowled scale plane like Sukhoi or Zero, just try to find a real aircraft's picture, and try to estimate the ratio of spinner diameter to the cowl diameter. |
RE: Spinner Sizing
Thanks to all that replied. I was just worrying..or concerned that too big a spinner would
tax the engine and make the pulling power of the prop diminished. Andy |
RE: Spinner Sizing
yeah all the spinners i have had really tend to flow rather well into the aircraft right after they hit the ground mr robison!!:D:D
RE: Spinner Sizing
Hey Tinman!!
You're just jealous because your spinners seldom last more than one or two flights. Haw. Good to hear from you again. Bill. |
| All times are GMT -8. The time now is 11:28 PM. |
