RCU Forums
-   Glow Engines (https://www.rcuniverse.com/forum/glow-engines-114/)
-   -   Difference between OS FX & AX ABL (https://www.rcuniverse.com/forum/glow-engines-114/2835722-difference-between-os-fx-ax-abl.html)
flight2000 04-02-2005 06:03 PM
Can someone tell me the diff. between this two config?
I want to buy a .46 and have this two options:
FX H-Ringed
AX ABL
The SX is slighty expensive.
flipstart 04-02-2005 06:40 PM
RE: Difference between OS FX & AX ABL
I own 2-OS 46 FXs and 2-46 AXs-all 4 engines start easy and run great. The AXs have slightly better transition and a little more power-FXs are about 3 years old and AXs are less than 1 year-for the money I would get the AX-take baffle out of muffler, and expect
13000 rpm with APC 11/6 prop on 15% nitro. With Tower discount that puts the AX at about $100, not bad for a reliable engine.
Ed_Moorman 04-02-2005 07:40 PM
The "H" engines are for helicopter use. They have the big heat sink head. You probably wouldn't want one of those in a regular airplane.
The OS .46AX is the follow on engine to the .46FX. It has a slightly different crankshaft, wider forward transfer port which led to a 4-bolt head instead of a 6-bolt. This led to a different design cylinder and head. It also has a separate needle valve assembly instead of the cast-on one on the FX.
