RCU Forums
-   Glow Engines (https://www.rcuniverse.com/forum/glow-engines-114/)
-   -   Please help, ASP 75 cutting out. (https://www.rcuniverse.com/forum/glow-engines-114/2837873-please-help-asp-75-cutting-out.html)
karolh 04-03-2005 11:44 AM
My ASP75 is fitted with one of the new series ST 75 carb for fuel economy, and the combo has always performed well. After recently replacing a split fuel tank and doing a carb strip down, I am having a problem keeping the engine running at idle.
The top end is fine, with a reasonable midrange which is typical of the ST carb, but is not a major problem.
The engine idles normally on an OS #8 plug with the starting battery connected, but as soon as the battery is removed the engine quits, yet it idles well with a Fox miracle plug when the battery is removed.
I have tried several new #8's with no change, what could be wrong. I would like to continue using the OS plug as it gives a good midrange response. I have checked all fuel lines for leaks and pressured the system, and used high temp RTV silicone to help seal the carb neck / engine to guard against a possible air leak.
What am I missing here ??
Flyboy Dave 04-03-2005 12:31 PM
RE: Please help, ASP 75 cutting out.
Your fuel might be getting stale....if the engine dies out when you remove
the glow it is usually bad fuel.
The Miracle plug is a hot plug, and works great in two cycles....why not
continue to use it ? ;)
FBD. :D
Turk1 04-05-2005 08:23 AM
Is it an inverted application?
karolh 04-05-2005 06:00 PM
No it is not an inverted installation, the engine is mounted sideways. I had never thought that the fuel might be stale as all my other engines run well on it, just as the ASP used to.
As Flyboy Dave suggested, I will stick with the Fox miracle plug, and as soon as I get a new bottle of fuel I will change back to the OS #8 plug and see if it makes a difference.
ChuckECM 04-09-2005 01:16 PM
Hey, I'm having a problem with my new st-75. Do you by chance know what a good starting point for the idle adjuster screw. Maybe 3.5 turns out? I just can't keep it running for longer than about 45 sec.
The manual recommends a high end starting point but no idle adj. starting point.
Chuck
karolh 04-09-2005 02:35 PM
Chuck, my ST 75 engine's idle needle is set at approx 3.25 turns out, and will idle all day at 2,800 rpm on a 12x6 MA prop.
I would suggest that you start with the needle set at 4 turns out and work from there. HTH
ChuckECM 04-09-2005 02:44 PM
thank you, I'll give that a shot!
