3 Engine Help Questions
I was just running some engines awhile ago, and noticed this:
1. My .91 FX is Rich, but it is hot when i touch the head after running it, 2. My .91FX Makes a "click" sound after the piston goes up near the head after the engine is run, and 3. My .91FX has less compression than my OS .50SX, is this right? Thanks!! |
RE: 3 Engine Help Questions
could someone respond please?
You might want to give people more than 11 minutes to respond;)
Sorry I do not have an answer for you, but relax.....you will get one soon... Just remember this is a board...not a chat room:D |
please someone
Just fly it and enjoy. Everything will be fine!
yeah, but I want answers to those questions
1) I would be more concerned if it wasn't hot. Hot is a relitive term. You can only hold your finger on about 130 deg. f.
2) The click is just the crank going over TDC. Don't worry unless it clunks. 3) The 90 is a ringed engine and the 50 is ABC or N. The 90 will not produce its full compression unless running. Quit worrying and go fly. |
BARCC:
I usually don't respond to OS threads, but it looks like DaveH, FBD, and W8YE are off somewhere else. Along with all the rest who might give an answer. 1. My .91 FX is Rich, but it is hot when i touch the head after running it, 2. My .91FX Makes a "click" sound after the piston goes up near the head after the engine is run. 3. My .91FX has less compression than my OS .50SX, is this right? Bill. |
| All times are GMT -8. The time now is 05:48 AM. |
