Idle mixture
Just want to settle a friendly discussion. Will the idle mixture screw affect the high speed needle setting on a glow engine like it does on gas engines? Or does it depend on the brand engine. (the one in question is a Saito).
Idle mixture
On carbs with dual needle setups, yes... generally speaking.
On carbs with air-bleed idle mixture control... no. The air bleed carbs merely open/close a small hole which allows outside air in. On the others, the low end adjustment also affects the overall fuel flow for a given throttle position. |
| All times are GMT -8. The time now is 06:12 AM. |
