RCU Forums
-   Glow Engines (https://www.rcuniverse.com/forum/glow-engines-114/)
-   -   Help with a ringed OS 50Sx (https://www.rcuniverse.com/forum/glow-engines-114/2989698-help-ringed-os-50sx.html)
steveg_oz 05-19-2005 05:42 AM
hi all,
I'm rebuilding an OS 50Sx, and I can't get the piston back in the liner. There's a champher on the bottom of the liner. I thought that this would compress the ring so the piston would slide in.
No luck. Is there a trick?
Regards,
Steve
Flyboy Dave 05-19-2005 05:49 AM
RE: Help with a ringed OS 50Sx
Look on the piston and see if there's a small pin that holds the ring in one
location....if the ring is not positioned properly, it won't fit back on. ;)
FBD. :D
steveg_oz 05-19-2005 06:04 AM
I'm not sure if the ring is pinned on the OS50. It seems to compress back into the slot okay
S
w8ye 05-19-2005 06:18 AM
On the 50SX there is a spring pin stuck straight into the ring groove on the left rear corner. The ring gap must be placed at this position or you cannot get the piston/ring up in the sleeve.
Enjoy,
Jim
Hughes500E 05-19-2005 11:41 AM
Use lubrication around the hole (bottom of the liner) and a bit on the piston. That will help!
Doesn't take much, you could even wet it with a spot of engine oil!
MOJO65-9or10 05-22-2005 03:12 PM
I got mine in WITHOUT knowing about that spring thingy. My 50 now is junk!!!! *****...
William Robison 05-22-2005 03:30 PM
Steve:
The 50 SX ring, as stated by several above, is pinned. If you force it the liner, piston, and ring are immediately converted into junk. OS prices being what they are, once you do that a new Magnum 52 is a far better deal.
If you get everything lined up properly it will slide together easily and give you more good service.
Bill.
Flyboy Dave 05-22-2005 07:25 PM
....[X(]....I didn't think you could get the liner down over the piston, with
the ring not properly located. [:o]
FBD.
MOJO65-9or10 05-23-2005 08:40 AM
You most certainly can. You then have a nice carb left over and just like the guy stated above can go out and get a Magnum .52 because that is exactly what I did. Tower had them on sale a while back for 79.99. That was cheaper than replacement parts and the darn thing pulls better than my 50sx ever did.
Dave
pennster 05-23-2005 09:17 AM
I just changed the bearings in my 50sx a few weeks ago and ran into the same problem. The pin is in the groove for the ring, but can be hard to see due to varnish or carbon buildup. Once you locate it and line it up with the opening in the ring, the piston will slide in easily. Good luck, Steve
