RCU Forums
-   Glow Engines (https://www.rcuniverse.com/forum/glow-engines-114/)
-   -   glow plug thread form (https://www.rcuniverse.com/forum/glow-engines-114/303697-glow-plug-thread-form.html)
taittinger 10-06-2002 08:22 PM
Is there anyone out there that knows the thread form of the thread of a standard glow plug? I know that the thread is a 1/4" x 32 tpi but what is the form (UNF, Whitworth...)
Without knowing the form I can't order a tap...
Thanks in anticipation.
Regards
bob_nj 10-06-2002 11:02 PM
Mine says...
That it's a Hanson, and a 1/4 32 NEF. Higley used to sell them. Hope that helps_bob
Pepe J 10-07-2002 12:20 AM
Bob's correct. I believe the "EF" stands for extra fine. You can find all this Info. in the "Machinery Handbook. Go to the local machine shop (or library maybe) and they should have a copy. Pat
JCM 10-07-2002 03:31 AM
For glow plug use either 1/4 x 32 NEF or
1/4 x 32 UNEF. Use 7/32 tap drill for 75%
thread.
Good Luck
taittinger 10-21-2002 06:20 PM
Thanks to you all for replying. I now have a thread in my sticky mitts :-)
taittinger 10-21-2002 06:21 PM
sorry, make that a tap in my sticky mitts...
Ladyflyer 10-21-2002 07:35 PM
When the threads are this fine they become very shallow in depth. Make sure your drilled hole is not at all oversize. Also make sure the tap is aligned with the hole for the entire tapping operation and a good TAPPING lubricant is used. Kerosene works well with aluminum if you don't have any commercial tap lube.
Good luck.
LF
bob_nj 10-22-2002 01:16 AM
lf
Is that website back up yet? Miss that baby...
