RCU Forums
-   Glow Engines (https://www.rcuniverse.com/forum/glow-engines-114/)
-   -   pulling bearings (https://www.rcuniverse.com/forum/glow-engines-114/3425731-pulling-bearings.html)
MACOREPO 10-05-2005 04:59 PM
pulling bearings
How do you remove the cam shaft bearings from an OS-91
jaka 10-06-2005 02:06 AM
RE: pulling bearings
Hi!
Just warm the case (I prefere a propane torch) and slam it against a piece of wood...and the bearing will fall out by itself.
Regards!
Jan K
Sweden
BarracudaHockey 10-06-2005 08:14 AM
If your not proficent with a torch or don't want to distort your case with uneven application of heat, throw it in an oven at 250 for 10 minutes, smack it against a block of wood and it should fall out.
This is written for a heli engine but they are pretty much the same http://www.raptortechnique.com/enginebearing.htm
