.12 CV engine problem
I ran my car for about 5mins had a slow speed roll over, turn the car idled down so it switched off. Tried to restart the engine when the engine started it revved really high no matter how low i move the idle on my control the car still idles to fast. What have i done. Thanks doods :P
Sounds like the throtle linkage either came loose,
or popped off. Also the screw that holds the throttle arm on the carb, may have come loose. Look closely at the barrel inside the carb as you work the throttle.....and you will find the problem. Dave. |
| All times are GMT -8. The time now is 03:24 AM. |
