RCU Forums
-   Glow Engines (https://www.rcuniverse.com/forum/glow-engines-114/)
-   -   Old fuel, split it or chuck it? (https://www.rcuniverse.com/forum/glow-engines-114/3694240-old-fuel-split-chuck.html)
bigdreama 12-26-2005 07:21 PM
O.k.
I'm getting into R/C again, after 10 years....I have some 5 year old redmax 12% syn-cas blend.....It's more yellow than red now and some evaperation has accured from a hole in the cap. Is there something I can split this with or should I chuck it?
I'll be running 40 size engines that are going get the once over before they hit the air.
I'm sure I'll get lots of dead stick time in, I just want to do it less than more.;)
piper_chuck 12-26-2005 07:30 PM
RE: Old fuel, split it or chuck it?
If it was unopened, it might be worth trying. Since it's been slowly evaporating, it's most likely not worth bothering with. Pitch it and save yourself the aggrevation.
w8ye 12-26-2005 07:35 PM
You could pour it around the foundation of the house to control weeds and insects
Broken Wings 12-26-2005 07:35 PM
Use it for bench running your engines, I've got some old Sig fuel with 25% castor that still works great. Just a thought...smiles
bigdreama 12-26-2005 08:31 PM
O.k. I think the answer is do it right the first time and chuck it.
Thanx
I just dusted off the credit card for some new toys from (Tower) it will slingshot me back into the grove. It also might get my butt in a sling when the wifey sees the new sig on the door step......."but it's going to become two planes for the price of one honey." oh well.
Thank you guys for the input. I'll put the old stuff in my kids plane...she can practice taxiing with that stuff.
Flyboy Dave 12-26-2005 08:54 PM
Chuck the "old stuff".......get some fresh fuel, you will be glad you did. ;)
(so will your engine)
FBD. :D
donkey doctor 12-26-2005 09:35 PM
Hello; Those guys must be fuel retailers, I'd try it first, then dicide. How do you get rid of un-wanted fuel nowadays? You can't toss it down a drain. If you find that it doesn't work for you, I would take what I had left to the local flying field and offer it around, there's always some cheapskate who will use it somehow.
Flyboy Dave 12-26-2005 09:49 PM
I fried a K&B .61 this season using some old fuel fuel, it was pink....it had
turned brown. I used it by mistake. You can believe it or not....your choice.
I had two buddies there watching my Ultra Stick fly. I noticed there wasn't
a smoke trail from the engine....I said it outloud. Before I throttled back to
land and richen up the mixture (I thought) the engine died. When I retrieved
the plane it was devoid of compression.
I haven't taken the engine apart, been busy....I just put another engine in
the plane.
My recommendation....dump the fuel. :eek: Been there....done that.
BTW....I'm not a "fuel retailer". :eek:
FBD.
piper_chuck 12-26-2005 10:06 PM
ORIGINAL: Flyboy Dave
the plane.
Kind of reminds me of the old oil change commercials, "you can pay me now or pay me later". My flying time is too little, and engines too expensive, even the cheaper ones, to be bothered trying to reuse old fuel rather than forking up $15-20 for a new gallon. :D
Flyboy Dave 12-26-2005 11:11 PM
....yup, Jim had it right....weed killer. :)
:D
da Rock 12-27-2005 09:47 AM
The stuff that evaporates out is the nitro, the nitro igniters, and the alcohol. If all that evaporated away, you'd be left with lube, right.
I got back into the hobby after 15-20 years. I had a shipping box of 4 gallons of RedMax. One of the bottles had leaked completely away. One was about halfway down. The other two were full to the top. After I'd used up the two good gallons (excellent fuel, that RedMax), I discovered that the closest LHS didn't have any fuel for sale with castor in it. So I bought a gallon of what they sold and did a little math. Blended in some of the old stuff with the new until I got down to the other LHS to buy some "fresh" fuel that had castor in it.
No way I'm throwing away perfectly good castor oil.
Sport_Pilot 12-27-2005 10:44 AM
Actually, unless the storage is above 97 degrees, the nitro stays behind. You will have nitro and oil remaining. If you knew you had a full gallon to begin with, you could replinish the missing methanol, and the fuel should be good. The oil should be good, the color ususally turns because sun or light exposure will eventually cause the dye to darken. You could try it on an engine on the bench to be sure.
HaveBlue 12-27-2005 10:55 AM
if its been sitting around with a hole in the cap the menthanol is probably saturated with water as humidity is menthanols worst enemy!!!..good advice here, buy fresh fuel !!!
Sport_Pilot 12-27-2005 11:16 AM
Only if stored under its flast point of 51 degrees F. The fuel will not asorb water when it is evaporating. It will be at a very slight positive pressure with vapors slowly pourning out the hole. Besides your engine will tolerate a lot of water, and you will be adding fresh methanol to the mix.
piper_chuck 12-27-2005 11:29 AM
ORIGINAL: Sport_Pilot
I could be wrong, but I believe fluctuations in temperature, such as the difference between day and night during the summer, can result in high humidity air being sucked into the bottle. When the water condenses on the side of the bottle, it's going to end up in the fuel.
Flyboy Dave 12-27-2005 01:24 PM
1 Attachment(s)
You can get good pure castor oil at the motorcycle shop. ;)
FBD. :D
3dbob37n 12-27-2005 01:37 PM
I don't know how many of you read the article in one of the rags, (can't remember which) but someone did a test to see if there was any truth to the old wives tale about water being bad for glow fuel. After much testing, using different quantities of water being put into the fuel, the tester could find no difference in engine operation until he got way up to 25% water in the fuel. I think the story appeared in one of the rags last year but not sure.
The result was that the quanties of water that might be in our fuel had to effect.
But, what about the rest of the stuff? What happens to the nitro or the oil?
Obviously, if there is the same quantity of fuel in the can as there was several years ago, then it tells me there was no evaporation and especially with the new plugs and caps that we have no days.
3dbob
FlyingPilgrim 12-27-2005 01:39 PM
I agree with the advise to dump the fuel in quesion, simply because it was exposed to the air for an extended period. I have used fuel that is years old (more than 3 years) with no problems, as long as it is sealed tight. I save the little red plastic stopper that comes in new containers to keep a good seal when storing over the winter months.
w8ye 12-27-2005 01:45 PM
In addition to age, sunlight has a lot to do with fuel spoilage. If you are going to store fuel make sure it is kept in the dark. At the field, don't leave your jug setting out in the sun.
I've used spoiled fuel to break in engines but there's all kinds of funny business sometimes happens with it. Won't idle, will not run unless battery is kept on the glow plug, engine quits for no reason, apparent mixture keep changing, cannot adjust needle to ever find the peak point, engine runs rough, etc.
Enjoy,
Jim
Sport_Pilot 12-27-2005 01:52 PM
Yeah, and it costs an arm and a leg! You can get it a lot cheaper from Fox, or Morgans. About $20 a gallon VS $9.00 a quart.
SaCCaL72 12-27-2005 01:53 PM
I have some 30% Heli fuel from last season, will it still be ok to use this up comming season again? After the season, I threw the cap on it tight and stored it in a dark area. Now the temp may have fluctuated from hot to cold but it was tight. Will this fuel still be ok? Also, I have a fueling cap on the bottle I am currently using when I go fly and just put the metal tip into the hole when I am done, is this a no-no? Should I remove the fueling cap and replace it with a normal cap until the next time I fly? I also have some 10% Tower Hobbies fuel that I don't use anymore that is probably at least 4 years old that has been sealed pretty well but I have no need for, are there any constructive uses for fuel other than for engines or killing weeds? Thanks in advance...
Sport_Pilot 12-27-2005 02:03 PM
Fluctuion from hot to cold will not make any differance unless the temp drops below 51 degrees. If the bottle is tight there is no problem. If the fuel level has not dropped (or increased) you can be 98% sure there is no proplem.
The main problem with old fuel is that the methanol evaporates if not tight, or if you have a very small hole. It causes problems with idling, power etc. But wouldn't you expect the same if you adde oil till it was say over 40% ?
NM2K 12-27-2005 02:26 PM
the plane.
FBD.
You're not one of those guys that sets the needle valve once and then never touches it again, are you, Dave? <Just kidding, Amigo>
I use old fuel from time to time, but not if it changes color. I've used seven year old fuel with success, but the fuel had been stored in the cardboard box it was shipped in, in my basement where the temperature was a constant 65 degrees. If my fuel has ever been opened, it is tossed after a year.
Yes, I've heard of folks using older, partial bottles of fuel without a problem, but I hate sticking piston rings. Lots of folks aren't aware of the fact that castor oil can go rancid over time. How can you tell if it is rancid? Frankly, I don't know. I suspect that it turns dark brown, but I'm not sure. Maybe there's a chemist or a lab tech in the crowd that can enlighten us. I hope so.
Sorry your engine fried. I love my K&B .61's like they are my own children. Fortunately, the fix is simple enough. But you know that, I'm sure.
piper_chuck 12-27-2005 03:37 PM
ORIGINAL: Ed Cregger
I use old fuel from time to time, but not if it changes color. I've used seven year old fuel with success, but the fuel had been stored in the cardboard box it was shipped in, in my basement where the temperature was a constant 65 degrees...
It's fairly common for people to have a wine cellar, but you're the first I've heard of who has a glow fuel cellar! [X(] Don't you think that's carrying the hobby to a bit of an extreme? :)
Flypaper 2 12-27-2005 03:56 PM
I use it for lighting the woodstove at the field clubhouse in the winter :D
