RCU Forums
-   Glow Engines (https://www.rcuniverse.com/forum/glow-engines-114/)
-   -   Super Tigre question (https://www.rcuniverse.com/forum/glow-engines-114/3751236-super-tigre-question.html)
ecrt123 01-09-2006 08:05 AM
Does anybody know where the factory setting for the low end setting is supposed to be?
I have a G45 that I bought from someone but he got the low end really messed up.
Ray
Dr1Driver 01-09-2006 08:26 AM
RE: Super Tigre question
There's only one good way to set a ST low end needle.
Place a short piece of fuel tubing on the inlet nipple. With the carb at idle, and the idle needle closed, blow through the tube. Hold the carb throat to your ear while slowly opening the low end needle. When you can JUST hear air blowing through, you're within 1/4 turn either way of the right setting.
Dr.1
Hobbsy 01-09-2006 09:11 AM
http://www.supertigre.com/faq/product-faq.html#q22
Dr1Driver 01-09-2006 09:32 AM
Rotating the spraybar IS an option IF your engine has midrange problems. However, in all the STs I've owned, none ever did. Guess I was lucky.
The method I posted for tuning an ST carb is tried and proven in the field (not only by me, but by many others), and it works, every time. There may be other methods, but this is the one I know works, and the one I use.
Dr.1
stg61abc 05-04-2006 10:54 AM
Dear Ray, try my method, its simple:
Take the carb out from the motor, and look the carb from the lower part, with the rotor fully opened ,the slow speed needle should be exactly in the half portion of the slot (the slot that resembles an "eye" in format), so adjust with an screwdriver (opening or closing the needle) until reach this ideal position.
mount the carb again, and this should give you a super smooth idle.
Minor adjustments may be required given the fuel type and altitude, but this method work very well indeed,
best wishes
Carlo
Brazil
Dr1Driver 05-04-2006 11:02 AM
Take the carb off? Simple? My method doesn't involve taking anything off that might not get put back on correctly.
Dr.1
NM2K 05-05-2006 01:13 AM
ORIGINAL: ecrt123
Ray
The best setting is - where the engine runs best. There is no other answer.
The reason I say this is because propeller size/model/composition, glow plug type, fuel composition, ambient weather conditions, etc., all make a difference as to how the engine will run at any setting, so there can be no specific setting given for a glow engine that will be universally correct. I am not trying to give you a hard time. I am trying to educate you a tad. In the end, you have to twist the screw and analyze the results. Two turns out is a good starting point on most engines.
Cyclic Hardover 05-05-2006 07:30 AM
ORIGINAL: Dr1Driver
Dr.1
This is the best way. It gets you very close and you can adjust from their. Rotating the spray bar has nothing to do with an intial setting. Maybe afterwards but that is not the original question here.
wcmorrison 05-05-2006 08:31 AM
ORIGINAL: Cyclic Hardover
ORIGINAL: Dr1Driver
Dr.1
He's right on. It is the Clarence Lee Method and it works. The others work too but Mr. Lee's method seems to be the easiest to set up, after that use the pinch test to get it right on.
Cheers,
Chip
REFODGE 05-10-2006 11:19 PM
Hi Col.
Hows things out West?
Ernie Misner 05-10-2006 11:51 PM
Even if the low speed needle is way off, the pinch test points you in the right direction if you don't have an extra piece of tubing handy to blow through.
Ray, do you know how to do the pinch test?
Ernie
