RCU Forums
-   Glow Engines (https://www.rcuniverse.com/forum/glow-engines-114/)
-   -   engine q's (https://www.rcuniverse.com/forum/glow-engines-114/3960615-engine-qs.html)
oddbal 02-25-2006 10:21 PM
engine q's
is [link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXZH53&P=7]Trinity After Burn Oil [/link] good oil to use in your engine after use
and is this ([link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXFPV0&P=7]Dubro Pit Stop w/Kwik Start Blue [/link]) a good product. how is the glow starter?
proptop 02-25-2006 10:30 PM
RE: engine q's
The glow starter is good...and if you need the rest of the stuff then go for it...
The after burn (after run ) oil sounds o.k. but you can go to AutoZone or someplace like it and get a bottle of Air Tool oil that will do the same thing. You'll get twice as much for the same $.
oddbal 02-25-2006 10:52 PM
RE: engine q's
will the air tool oil work the same
proptop 02-26-2006 12:42 AM
RE: engine q's
Air tool oil has anti corrosion additives and is probably pretty much the same stuff, just in a different bottle. Trinity needs your money though, so support our sponsors (do they ad here? ;):D)
You can also use Mobile 1 or automatic transmission fluid among others...
There have been numerous threads here about after-run oils...if you're curious just do a search and be prepared to do some reading :D
