RCU Forums
-   Glow Engines (https://www.rcuniverse.com/forum/glow-engines-114/)
-   -   Moki 1.80 question...... (https://www.rcuniverse.com/forum/glow-engines-114/4149916-moki-1-80-question.html)
hdcomp 04-10-2006 09:05 PM
Hello all, can someone tell me what size the shaft is on a Moki 1.80? The reason im wondering is i need to drill a true turn spinner back plate to fit the moki shaft. any help is appreciated. thanks!
seanychen 04-10-2006 10:16 PM
RE: Moki 1.80 question......
The threaded portion of the shaft is 10mm x 1mm. However, where spinner goes on, the shaft steps up to 12mm OD without thread. So you need to ream your spinner to a 12mm hole. I wouldn't recommend drilling it, unless you have a drill press and can ensure centering of the enlargement.
Fox sells a 10mm & 12mm reamer, with a 1/4" pilot. So what I do is to insert a plastic sleeve with 1/4" ID and 9mm OD (comes with a lot of plastic spinners) so this reamer's pilot will be centered in Tru Turn spinner's 9mm existing hole.
