RCU Forums
-   Glow Engines (https://www.rcuniverse.com/forum/glow-engines-114/)
-   -   Removing Shellac? (https://www.rcuniverse.com/forum/glow-engines-114/4273499-removing-shellac.html)
ross001 05-13-2006 12:30 PM
Removing Shellac?
Hi,
Can someone please tell me how to remove shellac from an engine.
I know there is a method when you diamantle the engine and boil it in anti-freeze, but I want to keep the engine assembled.
Is there anything I can mix to make something which will remove it?
Ross
Flyboy Dave 05-13-2006 01:15 PM
RE: Removing Shellac?
Do you mean burnt oil on the outside of the engine, or congealed oil
or varnish on the inner parts of the engine ?
FBD.
ross001 05-13-2006 02:32 PM
The burnt oil. The Gold/brown stuff on the head.
Is there any thing I can mix to help remove this??
Ross
NM2K 05-13-2006 07:14 PM
ORIGINAL: ross001
Ross
Yes, it is simple.
Remove all plastic parts and o-rings from the engine. Get an old crockpot, which is never to be used for cooking food again, and submerse the engine in pure anti-freeze (NOT the biodegradable kind). Put the crockpot on low heat and let the engine soak over night. It will look like new in the morning.
ross001 05-14-2006 08:16 AM
Thanks, will give it a go
Ross
Grelker 05-14-2006 05:46 PM
I've also read in an RC magazine that the Stripeze brand of paint stripper works and you can use it while the engine is on the plane, but be careful
