What engine mount for YS 63?
There doesn't seem to be a nylon engine mount that fits the YS 63. What are people using?
I've had good luck with the GP .35-.70 sized adjustable mounts.
I Agree
Adjustable mount
I have had a couple of adjustable mounts and they were very heavy. Can you tell me how much the GP mount weighs? Thanks.
Save some weight from the GP mount and use a Dave Brown. They list one for the 63.
Good timing - I was just looking at the Dave Brown site. I didn't see one that specifically mentions the .63, but based on the dimensions it looks like either their part #5060-5060 or 60FS-6004 will work.
Which one are you using? |
BTW I don't know what the GP mount weighs. I can throw one on the scale later tonight, if you'd like.
Originally posted by visioneer_one Good timing - I was just looking at the Dave Brown site. I didn't see one that specifically mentions the .63, but based on the dimensions it looks like either their part #5060-5060 or 60FS-6004 will work. Which one are you using? 90FS-9004 $7.00 for 4 strokes, rear intake/exhaust 1.600-1.700 in. ASP .91, O.S. .77 VF, .91, Supertigre .61, .75, .90, YS .61 |
dave brown mounts
The YS 63 is only 1.375" wide where the crank fits between the beams. There doesn't appear to be a Dave Brown mount that's right for the YS 63. The 4650 and 5060 mounts are too short. The larger mounts have too much space between the beams, which doesn't allow room for the mounting holes.
The closest fit is the 404L, but is is about .060 too narrow between the beams. The YS has flat areas on the sides of the crankcase where it fits between the beams, so you can't just bevel the corner of the beams a little bit. It would require quite a bit of material removal to fit the engine on this mount, but is probably an option. |
I know most guys don't want to spend the money, but I just ordered a Hyde soft mount for my YS 63. They have one made special for the YS 63.
Jim |
| All times are GMT -8. The time now is 02:09 PM. |
