RCU Forums
-   Glow Engines (https://www.rcuniverse.com/forum/glow-engines-114/)
-   -   Heavy Planes (https://www.rcuniverse.com/forum/glow-engines-114/436005-heavy-planes.html)
Trombe 12-23-2002 11:54 PM
Heavy Planes
I am trying to put a small camera into a Kadet LT 40. Would a 60 four stroke or a 46 2 stroke be better?
Hobbsy 12-24-2002 12:00 AM
WHich
Saito .56 or a .72 would be perfect. I have a Saito .56 in a H9 Cherokee 40 which is fairly heavy and it does well.
Trombe 12-24-2002 12:23 AM
Heavy Planes
LarryC 12-24-2002 01:46 AM
Heavy Planes
With that large wing a good 46 ball bearing would do it if you don't want to go with the four stroke.
Larry
Hobbsy 12-24-2002 02:47 AM
Dollars
$$$ not a factor if you want it.
Flyfalcons 12-24-2002 03:03 AM
Heavy Planes
A 46 will haul this plane + camera around just fine.
Trombe 12-24-2002 03:40 AM
Heavy Planes
$ is a factor because i'm 12. However the plane is trainer but I would rather have the four stroke for quiter operation were I live.
According to some reviews the Magnum 61 is a great engine.
Hobbsy 12-24-2002 01:15 PM
Heavy Planes
Smasher, you're absolutely right, I remember when I was twelve $4.95 was a big deal for a McCoy .36, which I still have and a McCoy .35 also. I know absolutely nothing about Magnums though, my friend w8ye knows a lot about them. Merry Christmas.
w8ye 12-24-2002 01:40 PM
Heavy Planes
The Magnum 61 will turn a 12-6 APC at 9700 whereas a Saito 56 will turn the same prop at 10,000 on 10% fuel. The Saito 72 turns a 13-6 prop at a little over 10,000. A Magnum 52 and the OS 52 turn a 11-6 prop at close to 10,000. A OS 46 caliber 2 stroke will turn a 11-6 at 12,000+. These would be ones like the Thunder Tiger Pro 46, GMS 46, Tower/Hobbico 46, and the Irvine 46.
If money is a problem and you need a lot of power, the Magnum XLS series 46 2 streoke might be in order. It's a new design that's just been out in the last 4 or 5 months. If you shop around, you might find one at a better price. They were on sale during the summer months. You have to make sure you are getting the XLS series and not the XL.
With a LT40 and a 46 2 stroke engine, loaded down with a camera, You need to run a large diameter - low pitch prop with the 46 2 stroke engines. I'm talking about a 12 X 4 prop.
When you run a 11" or greater diameter prop on a LT40 ground clearance begins to be a problem. You have to extend the nose gear all you can and put huge tires on it. Big tires are not a bad idea anyway if you not running on asphalt.
Good luck
Jim
Trombe 12-24-2002 03:08 PM
Heavy Planes
What kind of 3 bladed prop would the magnum turn?
w8ye 12-24-2002 03:22 PM
Heavy Planes
When you are converting to a three blade prop, you reduce the diameter by one inch. A 46 that uses a 11- 6 two blade, will use a 10-6 three blade.
The choices af props in the three blade variety is rather limited. They are generally only available in the 6" pitch range.
The evolution 3 blade from Horizon has a low pitch and is for a 46 size engine.
TerrellFlyer 12-24-2002 05:48 PM
Heavy Planes
.46 BB 2 stroke will haul the plane fine.
jon595 12-24-2002 10:56 PM
Heavy Planes
My daughter's LT 40 has a .46 Thunder Tiger, 11x6 prop. It has more than enough power (it will hover) for it's size and weight. If you added a light disposable camera it would not even notice the extra weight. BTW she has the ARF.
Have fun,
Jon
Trombe 12-24-2002 11:11 PM
Heavy Planes
Witch is more powerfull- the O.S. FX .46 or the ThunderTiger .46?
:confused: :confused: :confused: :confused: :confused:
Trombe 12-24-2002 11:14 PM
Heavy Planes
Oyeh- the camera is a Kodak APS atomatic advance camera-F350
Real light too :0
w8ye 12-24-2002 11:22 PM
Heavy Planes
In this case, the engine that is more powerful is the one that you get a better deal on.
Enjoy your Thunder Tiger,
Jim
Boomstriker 12-25-2002 07:09 PM
camera
Any .46 will pull it fine and a small light camera will hardly be noticed as far as weight goes.
Just be sure to use foam to mount the camera or rubber band suspension would be even better. If you don't, the pics will be blurry from vibs. Dropping to idle before snapping the shot works too sometimes.
I made a mount for the camera with a flex push-rod to push the button then used RB's to hold the mount. Worked great!
Kirk
