ASP 91 muffler
I lost the back of my asp 91 muffler. Does anyone know of a replacement, where Ican get a replacement or if any other standard muffler will fit?
RE: ASP 91 muffler
Magnum engines are the same as ASP.
But the old XL91 series is not made any more. The current "S" version has a squarish head and lloks like a OS 91FX. |
RE: ASP 91 muffler
Hi,
You should try just engines they will post to the usa and they are really good at helping out. www.justengines.unseen.org Jim. |
RE: ASP 91 muffler
Tony,
If your ASP has 34 mm (1.339") center to center distance, between the exhaust flange bolts, like Webra Speed .61 and OS.60/.61FSR engines, the MVVS silencers will fit it as they come. There is a choice of Pitts, normal, quiet, tuned pipe and mini-pipe. If it is a later OS clone, with bolt-through attachment, you will have to look elsewhere. |
RE: ASP 91 muffler
I think Morris Hobbies is the US dealer, I can only find the tuned and normal muffler on their site.
http://morrishobbies.com/default.php...5a6ed61d33f90b |
| All times are GMT -8. The time now is 09:19 PM. |
