OS 52FS and props
I have a SiG kadet lt-40 Kit.
I am planning to buy an OS 52FS What is the Prop i should use for running in the engine? Can i use a 12X4 APC? Also i would like to have the slowest possible speed. Do you think that a 13X4 it will be ok for 52FS? |
RE: OS 52FS and props
!2x4 is a bit light -12x6, 12x7, 13x4 or 13x5 would be good.
Prop it to do 9500-10000 static. |
I like the APC 12-5 on mine. They pull a APC 12-6 OK at around 9600, I just like the 12-5.
If you want it to fly slow, throttle back some. |
| All times are GMT -8. The time now is 08:10 AM. |
