RCU Forums
-   Glow Engines (https://www.rcuniverse.com/forum/glow-engines-114/)
-   -   Old O.S. .61 SF (https://www.rcuniverse.com/forum/glow-engines-114/4519752-old-o-s-61-sf.html)
Flyboy Dave 08-03-2006 03:50 AM
RE: Old O.S. .61 SF
ORIGINAL: jaka
Hi!
I hope you don't intend to replace your .46 engine with the .61 engine in your LT-40, despite the change to a float plane.
A .46 is perfect for such plane provided you run the correct prop! Try a 11x6 APC or a 12x4 APC.
Regards!
Jan K
Jaka....
....have you ever flown a float plane ? The drag is about twice the normal, in
flight. Getting airborne is even worse. :eek:
Putting a .61 engine on a .46 plane....the plane having been converted
to floats would be quite normal. Putting an APC prop will not help a darned
thing.....contrary to your mind-set....that no plane will fly....unless it is
equipped with an APC propeller. :eek:
Are you on planet Earth ?:D
FBD. :eek:
Bax 08-03-2006 09:44 AM
RE: Old O.S. .61 SF
Here are the stock numbers and list prices of the parts you asked about:
OSMG4945 27803000 CYL & PISTON 61RF ABC $114.99
These parts can be ordered through any hobby retailer who sells O.S. Max engines and accessories.
EyeflyRC 08-09-2006 04:16 PM
RE: Old O.S. .61 SF
I acquired an OS .61 Gold Head Special Addition used engine with an 86 carb. This carb is unusual in that it has the idle adjustment similar to the 7L but it has two fuel nipples. One by the high speed needle which is the normal location and one at the base of the carb near the throat of the crankase. This nipple is blocked off with a piece of tubing with a bolt in it. No piston ring on the engine so I guess it is an ABC.
I wonder if anyone knows the purpose of the second nipple and what makes it a Special Edition?
Thanks.
JustErik 08-09-2006 04:57 PM
RE: Old O.S. .61 SF
ORIGINAL: EyeflyRC
Thanks.
Can a newb jump in here??? :)
That second nipple sounds like a pressure tap, but I could be mistaken.
Flyboy Dave 08-10-2006 02:02 AM
RE: Old O.S. .61 SF
1 Attachment(s)
That carb is off a pumped engine. The second line is a return line, and
returns excess fuel back to the pump. It acts as a regulator, in that it
keeps the fuel pressure more or less constant, rather than having the
changing pressure effect the mixture setting to any great degree.
FBD. ;)
EyeflyRC 08-10-2006 05:36 AM
RE: Old O.S. .61 SF
Thanks.
Bax 08-10-2006 09:51 AM
RE: Old O.S. .61 SF
The inboard line is actually a line that senses carburetor vacuum. This will then adjust the regulator in the pump to change how fuel is delivered to the carburetor. When the engine's running low enough, it causes the return line to open and return fuel to the tank.
EyeflyRC 08-10-2006 11:50 AM
RE: Old O.S. .61 SF
I suppose you are referring to a built in pump. The engine I have does not have one. Would the carb be suitable to use with that nipple closed?
Flyboy Dave 08-10-2006 12:03 PM
RE: Old O.S. .61 SF
Bax might know better than I on that question. I would say yes, it might be
OK if you have good fuel pressure from the tank.
FBD.
BOLTMAN 08-11-2006 11:04 AM
RE: Old O.S. .61 SF
Guys
If it's torque you want, not speed, try an APC 13x7 on the 61SF. I run one on my ringed SF using 10% nitro & the engine just loves it. I would recommend this prop for your LT40 on floats if you just want more torque. Also the low pitch gives good acceleration ( handy in the water ).
Cheers
Sport_Pilot 08-11-2006 11:57 AM
RE: Old O.S. .61 SF
I would think that a 12-10 or so would cause the engine to be at a higher torque and speed. Did you mean thrust?
f3a05 08-11-2006 01:46 PM
RE: Old O.S. .61 SF
The type 86 carb was designed to run with pumped engines only.The throat is too big to draw fuel on carb suction only.
On the 61, you could probably use a perry pump in conjunction with the type 86 carb.
Incidentally, you can run the 86 carb successfully without using the return line from carb to pump--just blocking it off works.
You do get a bit more excess fuel spitting from the carb inlet though at low throttle.
I have used the type 86 carb for years on a variety of big 2-strokes,in conjunction with an RFP/SFP or Hanno special pump, (Irvine 150,ST2300,MDS148,MVVS160,0S 160), for F3a competition use,and it's just brilliant- always more power than the stock carb, and once set, it can be forgotten for months at a time.
rambler53 01-08-2007 09:53 AM
RE: Old O.S. .61 SF
I sold two OS RF .61 engines with the 7M carb on them. I accidentally sent them with 7L carb instructions because that's what was in the box. The buyer wants to know if anyone has the 7M instructions on how to set the carb up. I forwarded your cursory explanation of tuning the mid range, just wanted to know if anyone could make a copy and email it to me or use snail mail on it? Thanks either way.
shakeelsid 01-08-2007 03:13 PM
RE: Old O.S. .61 SF
Hi Dave,
Is that a ten year old 61-SF - vow.
I have brand new engines that dont look half as good[&o]
Daryl Martel 01-09-2007 01:02 AM
RE: Old O.S. .61 SF
I'm with Dave in that moving up to a .60 on a trainer with floats isn't a bad thing. I've sure found that the addition of floats really impacts performance, and that having the extra power available makes for shorter takeoff runs (added margin of safety).
Dave - Jaka is from planet earth. Sweden is just on the other side. Europe is really cool. I encourage you to try it! :^)
BTW. the .61 SF is the BEST running engine I've ever owned - what a great carb!
rambler53 01-09-2007 07:38 AM
RE: Old O.S. .61 SF
Glad someone likes the SF, I have two, what prop do you use? I don't seem to enjoy mine as much. The FSR and FX seems to wind up better, so I assume the SF is a stroker and wants more load than winding up? I've tried 11X7 and 12X6. What makes your SF run well? Also, plug and fuel type?
XTOL 01-09-2007 10:42 AM
RE: Old O.S. .61 SF
Yes...the 61 SF is a long stroke and is happiest if you prop
it in the mid 11K range. Mine did 11600 on an APC 12 X 6.
I removed the baffle from the stock muffler and it did the
same 11600 with an APC 12 X 7.
This is the combo I use on my Ultra Sport 60. CP 15%
fuel and OS 8 plug. Absolutely terrific running motor.
Wish I had another one.
Mike Hammer
rambler53 01-09-2007 10:58 AM
RE: Old O.S. .61 SF
1 Attachment(s)
Xtol, it's a small world, I have four Ultra Sports, 2 are 60s and 2 are 40s. I keep a 60 kit around to copy any pieces I would need to remake. Two Ultras have retracts, one has the exhaust pipe running inside the fuselage, an OS RF .61 shown. the SF I'm using a 12X6 and I'm not really thrilled with the performance of the engine. I'm leaning towards a Rossi .61 instead. If you want my SFs (two are here), pm me. I think the Ultra Sports are one of the best flying pattern planes around. I have no idea why they discontinued them.
NM2K 01-09-2007 12:50 PM
RE: Old O.S. .61 SF
ORIGINAL: krosypal
I just bought half a dozen or so .61SF ringed engines and one ABC w/pump (what the heck).
I get a kick out of these engines and how they will pull a heavily painted Kaos 60 straight up running a stock muffler as though the model isn't even there. Sometimes it is nice to do things without screaming at 14k rpm. <G>
Ed Cregger
Ed_Moorman 01-09-2007 05:01 PM
RE: Old O.S. .61 SF
I had a couple of the .61SFs, one ABN and one ring. I sold the ABN version, but still fly the ring engine every now and then. The best prop I have found is an APC 12-7. I didn't check rpm, but it flies every plane I have had it in better than any other prop.
rambler53 01-09-2007 05:16 PM
RE: Old O.S. .61 SF
Turns out this second hand engine had the wrong needle valve in it. Replaced that. Runs much better. I replaced all my OS engines for the more stout Webra Speed .61 and Rossi .61 engines sitting in the closet. What a difference. Even Morris Hobbies has a nice Mark .61 ABC with pipe and header for $150 shipped. OS's premium price just doesn't seem to hold a candle to true performance engines. I'm glad the resale value was in my favor in making the change over.
gscavey 10-07-2015 08:11 AM
Greetings,
I am looking at these older posts trying to troubleshoot erratic idle for an OS 61 SF (7L carb) I recently purchased. I assume the attached picture showing the notch towards the high speed needle is correct. Is there a way to make sure the mixture valve itself is in the right orientation and not rotated 180 deg as BAX said could happen and would give problems? I looked on the OS website http://www.osengines.com/parts/xr27781000.html and it shows a picture of the mixture valve for an 7L but I doesn't look right and is pictured below. Mine looks like a tube with a notch or hole in it. Does the "hole" in the mixture valve go towards the cylinder or forward towards the prop? Hopefully this will clarify future questions about the 7L mixture adjustment which is made by the upper concentric screw only. Clockwise is lean, counterclock wise is rich, and the notch being vertical is the midway point.
Thanks - Greg
http://www.osengines.com/parts/images/27781300.jpg
Bax 10-09-2015 06:40 AM
1 Attachment(s)
Here's the carb manual that has an exploded diagram. The little slit faces towards the propeller.
[ATTACH]2124532[/IMG]
Stoneweapon 10-30-2015 01:14 PM
Originally Posted by Flyboy Dave (Post 4577478)
The ringed .61SF is one of the best OS engines. The ABC versions are not ABC,
rather they are nickel cylinders that can self destruct. The ringed version will run
a very long time until the ring wears out. The SF and the RF are basically the same
port timing wise, the position of the exhaust being the only real difference. The 7L
carb is one of the best carbs ever made, and that it one reason the engine is so
desirable.
The best prop I have found for this engine is the Zinger 12-8. I have been running
this old Super Kaos about every weekend for way over 10 years. I have had a
lot of different props on it. It turns 11,400 RPM and runs 105 mph clocked. ;)
I wish the RF (rear pipe) engines were ringed, I blew up a nickel liner, and the liners
are out of production, and Performance Services doesn't make them anymore
due to lack of demand.
Hang on to those .61SF ringed engines, and get a spare ring for them while they
are still available. I use 15% PowerMaster in mine, and a K&B 1L plug. ;)
FBD. :D
I just learned that the SF61 ring is the same as the one for the OS 55 HZ-H.
tony0707 01-31-2016 11:50 AM
I own 3 OS 61 SF engines, two ringed and one ABC
No problem with the linner at all ,on the ABC engine ,which i attribute to the fuel i use ,Morgan Omega 15% ,and never run the engine lean
i was only flying for a short time,when this series of engines was release by OS (early 80's )
I got one early on ,so i have been enjoying this engine for many years
A long stroke engine ,not an RPM engine ,so more torque
I cannot say enough about how much i enjoy running this series OS 61
Engine is supper user friendly and puts out real good prop turning power
I run all my glo engines on the same fuel and a K&B 1L glo plug
I run a 12/6 apc @ 12,600 RPMs ( max on ground ) on my 60 Sig Super Cahos
This is one of those glo engines that is --just better than it is supposed to be
I have a 91 FX in my 60 Ultra Sport
That 91 is in a 60 size case ,so its light ,a strong choice for many 60 size performance airframes
Both the 60 Super Cahos and the 60 Ultra Sport --fly on rails , at a bit over 1/2 trottle ( at a fast crusie speed ) ,and have unlimited vertical ,with the other 1/2 throttle
Pictures of both the above planes are in my -Gallery , to the left of this post
Enjoy
