RCU Forums
-   Glow Engines (https://www.rcuniverse.com/forum/glow-engines-114/)
-   -   new evolution 52.... 2 stroker (https://www.rcuniverse.com/forum/glow-engines-114/4562395-new-evolution-52-2-stroker.html)
pault 07-30-2006 12:20 PM
i saw the new evolution 52 2 stroke at my lhs........any body run one yet....same footprint as the 46......cylinder is about 2-3 mm taller then the 46.....must be a longer stroke........129.00.........i wonder if its worth the extra cash.........thanks.....pault
Pit-Viper 1 08-12-2006 10:35 PM
RE: new evolution 52.... 2 stroker
yeah It does look good considering it says it will turn the same prop as the OS.91, anxiously awaiting myself for some input on this..
Shane
Ernie Misner 08-12-2006 11:41 PM
It is a tad larger and heavier than a 46 though. It kind of reminds me of a plane that I took a 46 out of and put a Magnum 52 XLS into. It definitely had more power but needed weight on the tail.
Ernie
skiman762 08-13-2006 04:51 PM
If it runs as good as the 45 and 46 it should be a nice engine without having to jump to full 60 size
blw 08-13-2006 09:57 PM
skiman- I agree. I have the 45 and 46 too. Great engines. Evo may be placing that engine to compete with the OS 50SX. If it runs as good as the 45 & 46 then it will be a better engine all the way around.
Ernie Misner 08-14-2006 12:14 PM
And competing with the Magnum 52 also. I bet I would have had a lot less deadsticks with the new Evo!
Ernie
JettPilot 08-14-2006 03:27 PM
I have an evo .45 and its GREAT :) Starts easily and runs all day ! I bet the .52 will be a great engine. More power for a negligable amount of weight.
What is the difference between the .45 and the .46 ?????
JettPilot
skiman762 08-14-2006 05:34 PM
ORIGINAL: JettPilot
JettPilot
the 45 comes with the flywheel it's called the evo training system they put it on the alpha forty and the arrow RTF not sure if the p-51 PTS uses it too or not
blw 08-14-2006 08:33 PM
JettPilot,
That has been the question about how Evolution has introduced their engines. The .40 (Alpha engine) and .46 share the same cylinders, crankcases, and carbs. You can make the 40 almost into a 46 by using the 46 liner and piston. That gives you a 45, but not the same .45 Trainer Power System engine at all. The crankpin on the 46 is slightly different to give it more stroke. If you put in a 46 crankshaft, you would then have a .46NT. The .40 Alpha is better balanced than the .46NT.
The .45 is a different engine and I don't think it shares any of the same parts. I haven't checked the carbs though.
skiman762 08-14-2006 10:44 PM
I do know the engine in the alpha 40 airplane is a .45
http://www.horizonhobby.com/Products...ProdID=EVOE100
blw 08-15-2006 08:14 PM
Skiman- yes, that is the .45 TPS engine. Another part of the confusion that I should have added is that Evolution called the .45 TPS a .40 for about a year.
sleeprcrx 08-19-2006 01:02 PM
i have one of the 52 and it turns a 9x8 apc 18000 rich with a tunned pipe.i have it on my mach racer
Pit-Viper 1 08-19-2006 01:48 PM
Isn't that a little small? I'm not sure thats why I'm asking. Looking to put this motor in a .40 sized mustang, just waiting to see if anyone does something similar. Was going to get an OS 50 but am going to wait a little longer.
Someone has got to have some more numbers on this motor, prop/RPM's/nitro%...etc..
Shane
Ernie Misner 08-19-2006 04:40 PM
Well, Magnum advertised the heck out of their 52 "turning 18,000" with a little prop like that.
Ernie
NM2K 08-20-2006 12:20 PM
ORIGINAL: Ernie Misner
Ernie
Did they say for how long? <G>
Pit-Viper 1 08-20-2006 12:23 PM
I may have to try that sometime, guess thats what the racers do anyway. Larger dia.= higher thrust so I guess smaller would yeild more speed. Just seemed so small when you look at the numbers. lol
Shane
