RCU Forums
-   Glow Engines (https://www.rcuniverse.com/forum/glow-engines-114/)
-   -   Which Pipe for Irvine .53? (https://www.rcuniverse.com/forum/glow-engines-114/479518-pipe-irvine-53-a.html)
gtalbot 01-13-2003 09:14 PM
Any suggestions for which pipe for a .53 sized two stroke?
The mounting and exhaust port are the same as the OS .46FX
I'm not sure if I can use the same as a .46 size or if I just have to adjust for the bigger .53...???
Ernie Misner 01-13-2003 10:10 PM
Since your bolt pattern is the same as most other engines in the 46 size range, the sky is the limit as to which pipe you can use. What are your needs?..... top rpms for speed only or a wide speed range for sport flying? Mousse can setups are nice because you can adjust the size of the can and the length easily.
Ernie
