eyna 120 4c HELP !!!
HELLO I RECIEVED A EYNA 120 4C IN A DEAL I GUESS THE PERSON I GOT IT FROM DECIEDED TO TAKE IT APART AND CLEAN WELL THAT SEEMED NOT TO WORK OUT ANY HOW IM IN THE NEED OF INFO ON THE CAM TIMING AND THE REASSAMBLY OF THIS ANY INFO OR PICS WOULD HELP ME THANK YOU ALL IN ADVANCE GUY
[email protected] |
Go to polk hobbies web site( sorry, can't remember the address)
They have the timing info, and even how to reverse the rotation. Any body out there remember their web address ? Good luck. |
Sorry, i meant model rectifier corporation (MRC)
Try Altech Marketing (under the same roof as MRC). Also be sure which one you have (may not make any diff. but....). The "Standard" 1.20 has the "120 4C" stamped into the case, The "R120" has the "120 4C" cast into the case (raised) and a larger crankshaft. They will send you a copy of the manual (they did for me, but can't find it!).
| All times are GMT -8. The time now is 04:45 AM. |
