RCU Forums
-   Glow Engines (https://www.rcuniverse.com/forum/glow-engines-114/)
-   -   Super Tiger 45 muffler (https://www.rcuniverse.com/forum/glow-engines-114/5121695-super-tiger-45-muffler.html)
rtn9105 12-15-2006 11:47 PM
does anyone know if the muffler for the Tower Hobbies 46
http://www2.towerhobbies.com/cgi-bin...?&I=LXJB16&P=0
will fit the Super Tiger 45? The description says it won't fit the ST 42 but it doesn't say anything about the ST 45.
w8ye 12-15-2006 11:51 PM
RE: Super Tiger 45 muffler
I used a Tower 46 muffler on a ST 45 for a few years. It almost fits. Just use a needle file on the exhaust port side of the exhaust stack. It will bolt right on. Just about .020" on each hole
rtn9105 12-16-2006 12:56 AM
Thanks for the info. I was hoping it was something small like that since they both say the bolts are 36mm apart.
I'm hoping the Tower muffler will be a weight savings over the stock muffler.
Did you notice any performance gains in your engine with this muffler?
w8ye 12-16-2006 03:15 AM
I cannot say. I never ran the engine without the Tower muffler.
speedster 1919 12-16-2006 06:05 AM
The Tower muffler is a big plus in weight saving and will provide some performance. I always use a little gray RTV sealant and no gasket on all mufflers. You get max backpressure and no oil leakage from that joint now. Enlongate the mount holes a little and your good to go.
Matthew Allen 12-16-2006 08:49 AM
ORIGINAL: rtn9105
This is slightly irrelevant, but the page doesn't even mention Super Tigre, it's talking about Thunder Tiger - I don't think ST ever even did a .42.
Matthew
