RCU Forums
-   Glow Engines (https://www.rcuniverse.com/forum/glow-engines-114/)
-   -   Glow Plug? (https://www.rcuniverse.com/forum/glow-engines-114/51367-glow-plug.html)
Hawk21 02-10-2002 12:47 PM
Glow Plug?
Can some one explain what is the difference between
a 4 stroke and a 2 stroke glow plug? a 2 stroke plug can
be use in 4 stroke engine?
THANKS in advance :)
rcuser006 02-10-2002 05:56 PM
Glow Plug?
Different heat! Due to the fact the 4-stroke does not fire on every revolution the plug needs to be hotter. Also the F is longer than the 8.
Use an OS #F in your 4-strokes and an OS #8 in your 2-strokes and you can't go wrong.
I wouldn't use the 2-stroke plug in a 4-stroke engine, it would probably be too short and too cold.
Scorpionjack 02-10-2002 07:11 PM
Glow Plug?
Maverick;
Sorry but the OS 8 is not good for all engines. All Engines have a particular heat range that they enjoy better than others. Not all engines operate in the same Heat Range. Experimentation is the only way to find optimum performance.
Granted alot of us use the F Type OS plug in four strokes, it doesn't necessarily mean it's the best we like them cause they last.
I've used cheap Tower plugs in some engines, Fox plugs in others, fireball in others, Thunder Tiger are right in there too. Enya and Rossi are few others not even mentioned.
For instance I found an MDS 40 that hates OS 8's.
Overheating — A glow plug coil will melt if it gets too hot. Reasons why this happens vary. Sometimes the combination of running a motor wide open with a lean setting before you take the glow plug heater off is too much for the element. Quite often people use a power panel which has a built-in surge characteristic, which results in momentary over-voltage when the plug is first switched on. When a glow plug fails due to overheating, the end of the element wire has a tear drop shape. Unless you have very unusual eyes, you cannot detect this without the aid of a microscope or magnfying glass. We use a 20 power microscope which brings it up where you can plainly see the end of the break.
Vibration — If the engine is not rigidly mounted and can move around very much, the element is shaken from side to side with tremendous "G" forces. This literally fatigues the metal until it breaks. When you look at the end of the element wire break through a microscope it has a jagged, rough type appearance. The only solution is to increase the rigidity of your engine mount.
Shock Wave — Most model engines use a steel or brass liner mounted on top of a cast aluminum case. As the engine gets older, the liner flange works its way down into the case and lowers the head with it. When the piston clearance gets down to about .010, air is forced out of the squish band area with supersonic velocity and the action on the glow plug element is like when a jet plane zooms over your house and knocks out the windows. The cure here is to raise the head with another head gasket.
Less often, reasons why glow plugs sometimes fail are:
Cranking the engine when it is flooded. This sprays raw fuel onto the plug and the droplets beat the element over to the side of the housing where it shorts out.
Another problem that occasionally occurs is that motors sometime take to wearing abnormally, such as a cracked cranshaft chewing metal out of the bearing, or a connecting rod that is chewing metal. Of course, when this metal goes up and deposits on the plug element, the plug burns out.
To make a blatant comment on one brand is wrong. Even though were all biased to a degree. YS Engines are the Best in 4 Strokes, but there is quality Sub-standard 4 strokes available too. : ) LOL
Have Fun
AMA 6518
rcuser006 02-10-2002 07:28 PM
Glow Plug?
Originally posted by Scorpionjack
Maverick;
I realise this and I know it was a generalisation. I also know that there are many different types of glow plugs with different heat ranges, lengths, idle bar/no idle bar etc. The different heat range also either advances or retards the ignition.
The OS #8 is a general purpose all-round sport plug. If you are using either high nitro or very low nitro then you may want to look at different plugs. YMMV.
My statement and yes maybe I should have been a little more clear, was that in everday general sport flying with most modern engines, using 10-15% nitro the OS #8 is a good place to start.
