t-15 hpi engine problem?
Hi,
I just bought a new Hpi T-15 Engine, and everyting i pull it to start its very hard to pull, seems like is getting stuck but it can still be pulled, and it makes something like a pinging sound. but It still starts and runs. can anyone help me with this? |
RE: t-15 hpi engine problem?
It could be you're just feeling the "pinch" of the tapered bore sleeve. The piston gets to a tight spot as it gets toward the TDC (Top Dead Center ) position.
If you take the glow plug out and pull the engine over slowly, how does it feel? |
ORIGINAL: proptop It could be you're just feeling the "pinch" of the tapered bore sleeve. The piston gets to a tight spot as it gets toward the TDC (Top Dead Center ) position. If you take the glow plug out and pull the engine over slowly, how does it feel? |
Hi!
It's normal! Just let it rew! But remember to always let it run a little rich. |
From your description, it sounds like the engine is o.k.(?)
The factory recommended needle valve settings are quite rich (usually ) and there could be excess fuel building up in the crankcase as well...you could be experiencing a partial "liquid lock" so if that happens, just tip the vehicle on it's side w/ the exh. stack pointing down and slowly pull it over (carefully, because you can break the recoil if you pull too hard ) to drain the excess fuel out. If you see a bunch of liquid fuel dripping out of the pipe, then that's what's happening (more than likely ) If you get a lot of raw fuel down inside the engine, it will be easier to un-flood it by taking the plug out and then pull it over several times as above. As you get a little run time on the engine, and get it adjusted properly, it will get easier to start. It also helps if you have a really good glow plug battery...one that makes the plug glow bright orange. |
| All times are GMT -8. The time now is 09:57 PM. |
