Question for Dar Z
Dar,
About a year or so ago, I read a post you submitted something like, 'how to set up your throttle servo linkage and/or carb throttle body to all work just perfect'. I have a friend who is having a lot of trouble getting his throttle cut on his futaba 7cap to work correctly. It's not getting enough rearward throw to close the thottle barrel completely not allowing the engine to shut off. I tried to explain your method to him, but was unable to fully explain it. Can you please resubmit the post if you're able to locate or simply re-explain your method. My buddy and I would surely appreciate it. thanks,, |
| All times are GMT -8. The time now is 08:10 AM. |
