RCU Forums
-   Glow Engines (https://www.rcuniverse.com/forum/glow-engines-114/)
-   -   Which Engine? DPM Ultimate (https://www.rcuniverse.com/forum/glow-engines-114/5246922-engine-dpm-ultimate.html)
flyerdave 01-11-2007 07:10 AM
DPM Ultimate 120 Biplane. What flavor will be best? The new OS 120 AX, OS 120 surpass w/pump, or Saito 125 four stroke. I am looking for dependability as well as power. Easy starting and smooth running! Thanks
w8ye 01-11-2007 07:26 AM
RE: Which Engine? DPM Ultimate
120 Surpass III
flyerdave 01-11-2007 09:39 AM
The specs on the os 120 surpass show much less horsepower than the 120AX, should this be a concern for the DPM ultimate and also what fuel is best with the 120 surpass 4-stroke? Thanks
Pepe J 01-11-2007 09:48 AM
Nothing less than a Saito 180 or YS 160 DZ IMO. Keep it simple, keep it light with lots of power. Do a search in the ARF forum, lots of tips there.
flyerdave 01-11-2007 11:42 AM
How about the YS 120 AC? I have never had a YS engine but have always heard good things.Thanks
Pepe J 01-12-2007 01:46 AM
The YS 120 AC would be the best choice if you're determined on running a 1.2 ci. four stroke in the Ulti. This plane weighs in at 12-13 lbs and there is a lot of drag being a bipe. A 1.2 will fly it, but not with authority. A YS 140 would be a better choice, but the 160 DZ would be the ticket.
If you wish to use a two stroke I would go with an OS 160 FX or a 1.8 Moki.
I have a Saito 180 in my Ultimate. I believe it weighed in at 12 Lbs-12 oz. It does fly quite well with very good vertical performance, but slow to pull out of a hover with a APC 18 x 6. If I had to do it over again I would go with 160 DZ.
malcolmm 01-12-2007 07:26 PM
ORIGINAL: Pepe J
Yep, no way you would get good performance from a 12 pound or more aircraft with a 120. Even allowing for slightly less weight for a 120, maybe 8 ounces less, it would still weight at least 11.5 pounds. Being a 2 stroke fan, and not being able to afford buying YS motors, I would go for the OS 160 FX.
Malcolm
Cyclic Hardover 01-12-2007 09:48 PM
Had a guy here at 5000ft with a YS 120 and it was very impressive in the DP Ultimate. Thing is the YS is an expensive sucker. If it were me, I'd spend iton a Saito180
