RCU Forums
-   Glow Engines (https://www.rcuniverse.com/forum/glow-engines-114/)
-   -   engine position at break in?? (https://www.rcuniverse.com/forum/glow-engines-114/56021-engine-position-break.html)
lownslo 02-17-2002 05:58 AM
I will soon be breaking in my .80 Saito. In the plane it is mounted on it's side. Does anyone know for sure if there is a potential lubrication problem (mainly during break in), with the engine cylinder in the horizontal postion. Any benefits??? Should I mount it upright on a bench stand??? What do you experienced engine guys think? Thanks lownslo
Bob
Rodney 02-17-2002 01:17 PM
Mounting position should not matter. The only problem might be (if you mount it inverted) is getting raw fuel in the combustion chamber and getting a fluid lock which could damage the connecting rod if you are using an electric starter. A side or upright mount should run and start the same.
Hobbsy 02-17-2002 01:23 PM
Saito on side
Bob, I was looking at some of my Saito's and they have the crankcase vent mounted in such a way that lubrication should be the same upright or horizontal, and I've seen many Saito's running inverted just fine also. MY .80 is on a Kombat 60 from the Airplane Factory and sideways is the only way you can mount an engine on it. So it has spent most of it's life on its side.
