RCU Forums
-   Glow Engines (https://www.rcuniverse.com/forum/glow-engines-114/)
-   -   CIPOLLA TSV four stroke engine ??? (https://www.rcuniverse.com/forum/glow-engines-114/5644854-cipolla-tsv-four-stroke-engine.html)
Chris.fr 03-31-2007 02:12 PM
I just found this cool engine in good condition without box and papers; it seems to be a 15-20 CC italian 4 cycle.
Every information available will be appreciated (TSV ?) , including the best way to purchase a new timing belt ! Thanks, Chris
My website : http://e.a.t.chez-alice.fr/AAmoteursminiatures.html
http://www.hiboox.com/images/1307/9b12bc2c.jpghttp://www.hiboox.com/images/1307/d185b83d.jpg
RVM 03-31-2007 03:48 PM
RE: CIPOLLA TSV four stroke engine ???
That's pretty damn cool.
on pipe 03-31-2007 08:05 PM
Neat engine! Although I couldn't find any info on your engine, Cipolla can be found at www.aumcipolla.it. I'm no good at Italian, but it looks like engine production moved to a different place in 2005. It looks like car engines are the main product now. (just like Novarossi, Picco, etc...) I have an .09 Cipolla two-stroke, bought about 2 years ago, but never heard of them before then. I might be of some help on the timing belt. I recently purchased an overhead cam OPS .120 four stroke, and wanted to get a couple belts for it. I found what I think will work at www.sdp-si.com. They have no minimum if you order online with a credit card. The belts that fit my OPS cost only $5.29 a piece. It is a non-interference engine, (valves cannot hit piston when belt jumps time) but I would still like to keep a fresh belt on it. It may never fly, but I would like to run it on the bench a couple times... As a note of interest, the guy I got it from said if you ever have a prop strike on the OHC engines the teeth usually strip off of the belt. Hope this helps, you have quite a collection of engines there, some interesting stuff! Ross
Chris.fr 04-01-2007 11:13 AM
Hi Ross,
many thanks for the infos, I could not resist the pleasure of dismounting the beast and it appears to be around 20 CC and has a rotating valve system too, as well as your OPS or more common Webra T4's or HP VT's but with a pair of drums, one for intake and the other for exhaust.
Very neat job inside :
I still need every infos you will have, thanks!!! Chris
http://www.hiboox.com/images/1307/849745ed.jpg
RVM 04-01-2007 01:59 PM
I really want one of these engines, just to have one if nothing else. How heavy is that engine?
ORIGINAL: Chris.fr
Hi Ross,
PlaneKrazee 04-01-2007 05:17 PM
Very nice engine.
Chris.fr 04-02-2007 05:20 AM
ORIGINAL: RVM
The weight is about 950 grammes, a little less than 2 LBS -Chris
