2 STROKE TO 4 STROKE CONVERSION
Hey guys, I've got an acrobatic plane in the works that calls for a .46 2 stroke. I'd like to install a Saito 4 stroke, what would be one to use? Maybe the .56 size Saito, or bigger yet? The plane has a cowl so need to stay with in the .46 2 stroke size.
I seem to like more than enough power, but everything has is limits. Most ARFs have a engine recommendation for either 2s or 4s. This one does not. For more than enough power I will usually step up a knotch from the recommended size, with no qualms about fabrications for fitting. I guess what I'm looking for is a "Rule of Thumb" for changing a 2s engine for a 4s, I know I need to go bigger, But how much? Thanks, Mando........... |
RE: 2 STROKE TO 4 STROKE CONVERSION
A rough rule of thumb is to go up one or two sizes (46 2 stroke becomes a 56 or 62 4 stroke).
I also like "more than enough" power. so for most of my 46 size planes, I use Saito 72's or 82's. Haven't found it to be a problem yet. The difference in weight and physical size between say a 56 and an 82 is minimal. |
if a 46 fits in there well the next move is alway a 91 4stroke on my book
Hi,
I had similar problem. The easiest power improvement is to go to two stroke .50 - 0.52 engine from OS(ringed), Webra, MVVS, SuperTiger(rigned) etc. Then you do not need any(!) modifications - it fits just 1:1 in the place where .46 was, and you usually gain power almost as ABC type of the .61 engines. Alternatively there isn't much you would gain from the 4 stroke, maybe sounds a bit funny like old barnstormer ... and some bit of fuel efficiency and maybe a lot more ... difficult to maintain engine, expensive too. It looks to me the facination of the 4-stroke has gone or it is going to away at least for the small engines below 1.0; well, let see what the others will say. Of course you get lower RPM more stable and higher torque at low RPM. But all that would require you to buy new type of glow plugs and new propellers, while moving from 0.47 to 0.50 you do not have to change almost any thing, you will just gain like 10-30% higher rpm and about 15-20% power increase too; i.e. 4-stroke is a bit of "waste of money show" (Well, some one might be right to say that the whole RC is that type "business"). At least there is one thing for sure: in all RC packages you get the reccomendation to use bigger 4-stroke engine in sense of displacement, that needs bigger size sleeve and piston and also valves-related mechanics and that is why Saito had to do special alloys to keep the weight comparable to 2-stroke, and then prices are not that low. Cheers, Nick |
Mando, If you want speed, go with the 2 stroke. If you want power go with a four stroke. I've flow a 40 size trainer with a O.S. 52 four stroke, and a 12 1/4x 3 .34 APC sport prop. It pulls like a tractor, but it isn't real fast. I've got a Sig 4* 60 with a Magnum 91 four stroke, and again it pulls like a tractor. It has more than enough power for any aerobatics you want. Straight up as far as you want it to go, and as slow as you want. I sure wouldn't replace a 46 witha 91fs though, it will way over power the plane. One other thing to watch is prop size. If the plane is setup for a 10" prop, you may have trouble with a bigger four stroke as they like big props. I crank a 14-6 with the 91 on my 4* and am tempted to go to a 15-4. Just some things to consider.
Don |
The old rule of thumb is to multiply the two stroke displacement by 1.5 so a .46 becomes .69 or .7 cubic inches. But modern four stokes are more powerfull today so you may get by on less.
I don't know a rule of thumb. However a Saito 72 or 82 will be just right.
David |
ORIGINAL: daveopam I don't know a rule of thumb. However a Saito 72 or 82 will be just right. David ------------- I'm with you, David. The .82 would be perfect in my book. The .72 is a bit too light in the power department for me. You're carrying nearly the same weight and size in a .72 as you are with the .82. You may as well enjoy the larger engine. I'm surprised that Saito is still making the .72. To a previous gentleman; You don't have to run large diameter props on four-strokes. You do need to run enough load on the engine to put it in its desired rpm range. There is nothing wrong with running an 11x10 or 11 on an .82 instead of a 14 or 15 something or other. Yes, prop efficiency goes to hell in a hand basket, just like it does on a .61 two-stroke running the same prop. But sometimes it is the best that one can do under a particular set of circumstances. Ed Cregger |
Well, you would have to buy new props if you changed from a .46 to a .61. Some 2 stroke engines run fine on Saito SS 4 stroke plugs and they are cheaper than the popular OS #8.
I have both, but prefer 4 strokes. I like the instant power instead of waiting for a 2 stroke to wind up. If you are going to do anything like loops or other things that need vertical power you may end up liking 4 strokes better. I like to fly pattern, so that's important to my kind of flying. The fuel savings are real. My jug empties much faster on the days that I'm flying a 2 stroke engine. Most 4 strokes stay tuned longer than 2 strokes. 8*) |
I replaced an OS 46AX with a Saito 82 on a Funtana X50, and I was VERY happy with it. Unfortunately, I snapped the wing off of the Funtana, so I don't have that plane any more, but I don't feel that it was the engine's fault. Would the same thing have happened with the .46? Probably not, because it didn't have nearly as much power as the Saito did, but I pushed that plane to a point BEYOND it's limitations.
The 82 Saito powered that plane into snap rolls plane faster than I could count the revolutions - no kidding! It sure was fun while it lasted. If I had backed off of the throttle, just a LITTLE, perhaps I wouldn't have lost that wing though. So, I guess what I am saying is - go for the 82 Saito, but just use a little judgement on the throttle. These planes, just like real ones, DO have limitations! BTW, the Saito survived the Funtana's demise just fine, and it is now on a Showtime 50. I haven't flown the Showtime - yet! |
All good Feedback guys, with lots of good variables such as props and power with a small amount of weight difs between engine sizes.......
We'll be look'n for power over speed on this acrobatic plane, and won't want to wait for the RPM to build on the 2 stroke. Flying weight will be about 6 lb. with a wing area of 531 sq. in. Looks like the .72 and .82 Saito are the same size for mounting, with the .82 1oz heavier. Compared to the .46 2 stroke they are only 25 mm longer and 6 mm wider. I'm running a Saito 100 on a 10.5 lb warbird with great results with power and fuel savings. Mando......... |
There is nothing wrong with running an 11x10 or 11 on an .82 instead of a 14 or 15 something or other. Yes, prop efficiency goes to hell in a hand basket. |
Too many people undersell the fourstrokes power because they don't grasp the difference between HP and flying power. That difference is far closer than 1.5 to one.
Sport Pilot- You have that reversed. You will gain prop efficiency with a larger diameter.
Sport Pilot- You have that reversed. You will gain prop efficiency with a larger diameter. |
No, I'm not confusing anything. It has to do with differential pressures, regardless of pitch, etc. Also, it does have to do with both airspeed or static speeds as you have to put those into the equasion to figure either 'ideal efficiency' or Froude efficiency. In a nutshell, the less pressure differential across a span the greater the prop efficiency. A smaller blade has a short span which increases the differential, and smaller blades generally turn faster with higher differentials. Both bring the efficiency down for the prop.
This is actually on the subject for this thread because 4 strokes are often chosen to swing larger props. |
One should specify the efficiency you are discussing. If one was talking about propulsive efficiency, as one would expect when talking flying aircraft, one would need to determine the power output to get a specific airspeed. Then we could discuss it. Otherwise we are guessing. Theoretically a higher pitch prop one a clean airplane would go faster. but a lower pitch prop on a draggy aircraft could be more efficient. If you don't have the thrust, power, and drag plot of the aircraft and prop you don't know.
Now, BLW is correct that for a fixed POWER the larger prop will be more efficient in any case. At fixed RPM and POWER as we have with an engine you have to deal with what I just mentioned. In electric models you can usually gear to whatever RPM you want and generally used as large a prop as possible. I have flown an Ultra Stick Lite with a 19x14 prop at 4500 RPM on electric. |
Theoretically a higher pitch prop one a clean airplane would go faster. but a lower pitch prop on a draggy aircraft could be more efficient. If you don't have the thrust, power, and drag plot of the aircraft and prop you don't know. |
I suppose methanol and nitro are cheap so efficiency may not be important to some. Posts above indicate that a modeler might spend a good amount of money for improved fuel efficiency of a four stroke engine, why not take it to the prop? Propulsive efficiency is power in the fuel/power output. That includes prop and engine. So if you spend hundreds extra on an engine, what is a few bucks trying a handful of props to get the performance you desire? Optimized you would pay for the props pretty quickly in reduced fuel comsumption.
Prop efficiency was very important in electric model prior to LiPo. That's where I'm coming from. I wouldn't consider a Cessna to be a draggy model aircraft. I was thinking in the model realm of a WWI biplane or triplane compared to virtually any sport model. You raely see a prop with a P/D of greater than 50% on a WWI model. |
propulsive efficiency is power inthe fuel to power output. |
Yes, it's important to some.
I have an FS-48 diesel that burns 12oz an hour at WOT. If you don't like what I'm saying just say so. If it's wrong prove it. |
ORIGINAL: mando SNIP Looks like the .72 and .82 Saito are the same size for mounting, with the .82 1oz heavier. SNIP Mando......... [link=http://photos.imageevent.com/ken6ppc/scannedos120manual/large/Scan20010.TIF.jpg]Specifications in Saito Brochure[/link] |
ORIGINAL: Ken6PPC The .72 is 8 grams heavier than the .82, according to Saito's specs! Click on the link below: [link=http://photos.imageevent.com/ken6ppc/scannedos120manual/large/Scan20010.TIF.jpg]Specifications in Saito Brochure[/link] Specs Type: 4-stroke Displacement: .72 cu in (11.80 cc) Bore: 1.06 in (27.0 mm) Stroke: 0.81 in (20.60 mm) Cylinders: Single - Chrome Plated Total Weight: 16.6 oz Engine (Only) Weight: 16.0 oz Muffler Weight: 0.6 oz Crankshaft Threads: M7 x 1mm Benchmark Prop: 13x8 APC @ 9,800 Prop Range: 12x8 - 14x8 RPM Range: 2,000 - 12,000 Fuel: 10%-30% Synthetic Mounting Dimensions: 104 x 56 x 111 mm Muffler Type: Cast Cylinder Type: AAC Carb Type: Barrel, 2 Needle valve Crank Type: Ball Bearing Specs Type: 4-stroke Displacement: .82 cu in (13.80 cc) Bore: 1.14 in (29.0 mm) Stroke: 0.80 in (20.40 mm) Cylinders: Single - Chrome Plated Total Weight: 17.6 oz Engine (Only) Weight: 16.0 oz Muffler Weight: 1.6 oz Crankshaft Threads: M7x1mm Benchmark Prop: 13 x 8 APC Prop Range: 12 x 8 - 15 x 4 RPM Range: 2,000 - 12,000 Fuel: 10% - 30% Synthetic Mounting Dimensions: 104 x 56 x 111 mm Muffler Type: Cast Cylinder Type: AAC Carb Type: Barrel, 2 Needle Valve Crank Type: Ball Bearing Mando.............. |
I was talking about fixed pitch props, like we use on models, at varying RPMs and in flight. The best pitch and/or diameter to use is based upon figuring out the efficiency based upon a formula that includes airspeed. You can't have large diameter and a large pitch for most engines, so you have to make a choice. That would be what it is all about in the end. Getting the most out of an engine and airframe. You could call it calculating the pulling power of the prop, or whatever. A lot of people think that only the highest RPMs give the most power.
You can use a smaller diameter prop for faster RPMs and reach a point where it is the most efficient. If you get the tips near the speed of sound your performance will drop quite a bit. You can do the inverse and choose a larger diameter to reach peak prop efficiency. The large diameter wins out in efficiency if used on the same engine, same airframe, etc. |
Larger diameter prop = more thrust ?
With the height of the front of the airframe that I have, looks like I could comfortably mount up to a 16" diameter prop. But with engine size compatibility for this plane I would only be allowed a 13"-14" prop. Mando.......... |
ORIGINAL: mando ORIGINAL: Ken6PPC The .72 is 8 grams heavier than the .82, according to Saito's specs! Click on the link below: [link=http://photos.imageevent.com/ken6ppc/scannedos120manual/large/Scan20010.TIF.jpg]Specifications in Saito Brochure[/link] SNIP Mando.............. [X(] If I had my .82 off of the plane, I'd just weigh it and post the results. |
ORIGINAL: blw I was talking about fixed pitch props, like we use on models, at varying RPMs and in flight. The best pitch and/or diameter to use is based upon figuring out the efficiency based upon a formula that includes airspeed. You can't have large diameter and a large pitch for most engines, so you have to make a choice. That would be what it is all about in the end. Getting the most out of an engine and airframe. You could call it calculating the pulling power of the prop, or whatever. A lot of people think that only the highest RPMs give the most power. You can use a smaller diameter prop for faster RPMs and reach a point where it is the most efficient. If you get the tips near the speed of sound your performance will drop quite a bit. You can do the inverse and choose a larger diameter to reach peak prop efficiency. The large diameter wins out in efficiency if used on the same engine, same airframe, etc. Prop efficiency is Thrust HP devided by Brake HP. Thrust HP is basically the thrust multiplied by the RPM, so you can basically divide thrust by the torque the engine is putting out. So airspeed is related only as far as it affects thrust. The low pitch prop will have little thrust at airspeed and will have a lower efficiency at speed than in climb and static. The high pitched prop is just the opposite. Since we are talking about increasing pitch and reducing diameter to keep the engine at the same RPM the high pitched prop will have more thrust and higher efficiency. Airframe and engine will not make a large differance here. |
ORIGINAL: mando Larger diameter prop = more thrust ? With the height of the front of the airframe that I have, looks like I could comfortably mount up to a 16" diameter prop. But with engine size compatibility for this plane I would only be allowed a 13"-14" prop. Mando.......... |
Displacement: .72 cu in (11.80 cc) Bore: 1.06 in (27.0 mm) Stroke: 0.81 in (20.60 mm) Cylinders: Single - Chrome Plated Total Weight: 16.6 oz Engine (Only) Weight: 16.0 oz Muffler Weight: 0.6 oz Displacement: .82 cu in (13.80 cc) Bore: 1.14 in (29.0 mm) Stroke: 0.80 in (20.40 mm) Cylinders: Single - Chrome Plated Total Weight: 17.6 oz Engine (Only) Weight: 16.0 oz Muffler Weight: 1.6 oz |
Thrust HP is basically the thrust multiplied by the RPM,..... http://www.answers.com/topic/thrust-power http://www.auf.asn.au/groundschool/propeller.html The actual airspeed achieved is the important figure. The theoretical thrust of a prop at a certain airspeed is insignificant if the aircraft never reaches that speed. You could have a model that is draggy enough that a high pitch prop will cause it to fly slower. Not only that, take off performance would be miserable. It all depends on how much drag the model exhibits, desired airspeed, and available power. You won't make a DR-1 fly any faster or more efficiently by putting a square prop on it, unless you can reduce the RPM to allow a larger diameter at the same HP input. This is what BLW is eluding to. |
Sorry, this is wrong. It has nothing to do with RPM. The actual airspeed achieved is the important figure. The theoretical thrust of a prop at a certain airspeed is insignificant if the aircraft never reaches that speed. You could have a model that is draggy enough that a high pitch prop will cause it to fly slower. Not only that, take off performance would be miserable. It all depends on how much drag the model exhibits, desired airspeed, and available power. You won't make a DR-1 fly any faster or more efficiently by putting a square prop on it, unless you can reduce the RPM to allow a larger diameter at the same HP input. This is what BLW is eluding to. |
Greg- thanks. Airspeed is important as it is calculated with the speed of the prop.
Sport pilot- the arguing is getting to be a drag here. I didn't want to dig out any books about it. You do factor in output power divided by shaft power input for thrust. But, that is only the beginning and you are fixated that this is the end of it. In short, it is thrust x velocity divided by thrust x velocity (prop) times velocity (airspeed). This is where the higher prop velocities of the smaller prop brings down the efficiency, as you already argued against. |
Its not the airspeed of the plane, its the increased airspeed of the air going through the prop This is getting old. Why do I bother trying to correct people's misconceptions on these stupid discussion forums? Especially when people don't care to listen. Why? So the others that think they are learning something, can learn the truth instead of repeating opinion, hearsay, false truths, half truths, etc...... If you are stating opinion please precede it with the usual internet method of, "I heard", "my friend told me", "I read online", "I think", etc. If you are stating fact quote your source or experience. There is a method to calculate power from thrust and air velocity, but this isn't thrust power as in the calculation of propulsive efficiency. |
ORIGINAL: blw Greg- thanks. Airspeed is important as it is calculated with the speed of the prop. Sport pilot- the arguing is getting to be a drag here. I didn't want to dig out any books about it. You do factor in output power divided by shaft power input for thrust. But, that is only the beginning and you are fixated that this is the end of it. In short, it is thrust x velocity divided by thrust x velocity (prop) times velocity (airspeed). This is where the higher prop velocities of the smaller prop brings down the efficiency, as you already argued against. Prop efficiency is THP/BHP thats it. Another formula is (Thrust * Axial speed) / (Resistance torque * RPM). The factors you mention do affect the BHP but since we are talking about two props being turned by the same engine at the same speed then the BHP is the same. You are saying the highere velocity brings the efficiency down, but it doesn't it brings it up. You are confusing the tip loss with high RPM. This is not a factor here as both propellers are turning at the same speed, in fact the tip velocity of the smaller prop will be less so there will be less loss there also. Edit xx Getting confused here. If a prop of the same diameter is used and turned at a constant speed then the thrust goes up as well as the velocity of the prop blast with increased pitch. Buy if the prop is made smaller to keep both speed and power equal then the thrust goes down and the speed goes up even more than in the first case. Using the Thrust HP calculator if one is to turn a 12-6 at 10,000 RPM then the Speed is 56.83 MPH, HP is .889, and thrust is 6.22 Lb. Turning a 11-8.5 at 10,000 RPM results in; Speed = 80.49 MPH, HP is .889, and thrust is 4.39 Lb. Thrust x HP is almost the same with the smaller prop being slightly less, thus vey slightly less efficiency when static. However at an aircraft speed of say30 MPH then the speed (leaving velocity - incoming velocity) of the larger low pitch will only be about 27 MPH (likely better because the angle of attack would improve) and with the smaller pitched prop the velocity differance is 50 MPH. Thrust should come down about as much as the velocity; so at speed, the smaller higher pitched prop should be more efficient. I am sure there are times when the opposite is true, but most of the time I think the smaller higher pitched prop will be more efficient except when static. |
OK, you are right and text books are wrong. If you didn't read or even browse the second link I posted, read the first paragraph under section 5.2. |
New, out of the box, Saito .72
Engine weight = 16.5 oz. Muffler = 1.7 oz. |
ORIGINAL: mando New, out of the box, Saito .72 Engine weight = 16.5 oz. Muffler = 1.7 oz. However, since I now have a brand-new 1.25 that followed me home, I thought I'd compare the actual weight to the listed specifications: Actual - 617 grams w/o muffler, 699 grams with muffler (21.76, and 24.64 oz.) Specs - 620 grams from both the brochure and the instruction booklet (21.87 oz.) Looks like my 1.25 weighs pretty close to what the specs say! |
1 Attachment(s)
Saito .82/stock muffler, Saito 1.25/TurboHeader and Saito 1.25/stock muffler, all nuts and washers in place plus home made velocity stack on the 1.25.
| All times are GMT -8. The time now is 07:31 PM. |
